    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 8 of 8
Thread: Phobya 200mm Radiator
    Mar 2010
    UK
    Hey guys,
    Can anybody tell me how well the Phobya 200mm radiator stacks up the defacto 120mm rads? How many 120's is it roughly comparable too?
    These rads seem to fit well within a case I am planning for my SR-2.
    Thanks in advance!
    Mudgey
    I7 920 at 4.0ghz - EK Supreme HF
    P6T Deluxe V2 Mobo - EK Mosfet & EK NB/SB
    6gb Corsair 1600mhz RAM
    Zotac 470GTX - EK FC
    2x 60gb OCZ Vertex 2 RAID 0
    140mm External Rad Stands Available Here
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Quote Originally Posted by Mudgey View Post
    Hey guys,
    Thanks in advance!
    Mudgey
    Go for it if it fits. You could use frontal surface area as an approximate conversion.
    20cm x 20cm or 400cm^2
    MCR320 is about 12.8CM wide by 36.2CM or 463cm^2
    MCR220 is about 12.8CM wide by 24.2CM or 310cm^2
    So, assuming you had the same fan performance, it would probably fall somewhere between a double and triple rad as a guess.
    Not sure on what a "Good" 200cm fan is though, that might be the bigger challenge since they are almost all designed for low resistance/case fan type duties.
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    I'm guessing that 180-220 fan selection is very scarce, so if it's much harder to find good 140mm fans compared to good old 120mm ones, imho it's gonna be only worse by going bigger. IIRC only 1 or two fans are sold of that size. I'm guessing they also have very bad air pressure because of slow rpm-s and big distance between fan blades. So not worth to compare rad area only, if available fans are not up to job. From these i'd probably would pick Yates 220 fan. But even better - 3x120 rad with scythe gentle typhoon fans
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    Quote Originally Posted by churchy View Post
    I'm guessing that 180-220 fan selection is very scarce, so if it's much harder to find good 140mm fans compared to good old 120mm ones, imho it's gonna be only worse by going bigger. )
    http://www.silverstonetek.com/produc...FM181&area=usa
    It is a very good 180mm fan.
    Apr 2006
    Hong Kong
    Sorry for the mega bump
    I'm thinking about 2 of these in the top of my Stacker STC01 and the silverstone fans are what i'm looking at.
    These specs are pretty impressive:
    SPEED
    1300 rpm +_ 200 rpm at VR=0Ω ~
    500 rpm +_ 200 rpm at VR=50KΩ
    AIRFLOW
    65~150 CFM
    STATIC PRESSURE
    Max 0.48~2.38mmH2O
    "Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
    2600K | GTX 580 SLI | Asus MIV Gene-Z | 16GB @ 1600 | Silverstone Strider 1200W Gold | Crucial C300 64 | Crucial M4 64 | Intel X25-M 160 G2 | OCZ Vertex 60 | Hitachi 2TB | WD 320
    Oct 2004
    London UK
    I know this is an old thread but would the Antel Bigboy be a suitable partner for this rad? Are there any other 200mm super coolers?
    Respec'
    System:Bunch of crappy overclocked PC's that cost an arm and a leg
    I am Xtreme
    Oct 2005
    Quote Originally Posted by RADCOM View Post
    Silverstone AP182 is a better choice.
    Oct 2004
    London UK
    Quote Originally Posted by lowfat View Post
    Thanks I'll look into grabbing one of them
    Respec'
