Guys on this CHIV I set the CPU-NB to 1.30v in the bios and when I go to AOD it reads 1.15v and when I go to TurboV EVO it reads 1.30v is it normal for AOD not to read a 1090T right? Next question is what is the best bios to run, I am running 0905.
ASUS CROSSHAIR IV, AMD 1090T @ 4.2GHz, 24/7, 8GHz DOMINATOR GT 1600MHz C6, 2X MSI HD5850 TWIN FROZR IN CROSSFIRE, 2X VERTEX2 120GB IN RAID 0, SOUND BLASTER X-FI TITANIUM FATAL1TY CHAMPION SERIES, 1600WATT ULTRA X4, THERMALTAKE XASER VI CASE.
AMD Overdrive does that with all CPU's in almost all boards.
Doesn't matter what combination of gigabyte/asus/965BE/bios I use it does that. You sure are making a lot of these threads...
Smile
you will not know IF you don't ask! This mobo is the first asus board I have ever had so I ask questions to be sure, With that said I am sorry I bothered you..
he'll be able to make a phenom II 6x FAQ later.
