I cant seem to get the temps of all 6 cores to show in several different software applications.Can anybody recommend some software that shows all 6 core temps.
Xigmatek Elysium Case
Intel I7-3770K
Asus Sabertooth Z77
16 Gigs Ripjaws 2133mhz Ram
Mushkin 240 SSD
Lightscribe Dvd Burners
EVGA GTX 680
Aquacomputer Gpu Block
Cooler Master Hybrid 1050 Watt Pws
EK Supremacy Cpu Block
Xspc RX360 Rad
Xspc XS360 Rad
Phobya 250 Balancer Res
2 x Mcp 350 Pumps
coreTemp:http://www.alcpu.com/CoreTemp/
ASUS P8P67.rev3
i5 2500k
2x2 G Skill F3-17000CL9-2GBXL
XFX Radeon HD 6870
psu: corsair 600 watts
creative xfi extreme music
or Real Temp GT
Gaming/General Usage | Win7 64
Gigabyte GA-X58A-UD7
I7 930 (3003A965) @ 4.2 (200x21; CL7-8-8-24/1600; VCore=1.35V)
OCZ3F1600LV6GK 6Gb
PowerColor 5970 @ 900/1110
X25M 80G G1 X2 Raid0, Xonar D2X, Antec 1000W.
Swiftech Apogee XT
EK Waterblocks EK-FB KIT
XSPC 5970 Full
Swiftech MCP655
Feser X-Changer QUAD 480
EK-Multioption RES X2 - 150 Advanced
Scythe GentleTyphoon 120, TJ07
aida64 formally everest
5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
u know the core temps are way off right?
This is ture, about 10*c cooler then actual.
~1~
AMD Ryzen 9 3900X
GigaByte X570 AORUS LITE
Trident-Z 3200 CL14 16GB
AMD Radeon VII
~2~
AMD Ryzen ThreadRipper 2950x
Asus Prime X399-A
GSkill Flare-X 3200mhz, CAS14, 64GB
AMD RX 5700 XT
Thubans features only a single diode for core temperature measuring. There are different tools that display temperatures for each core, but those tools just mirror the same temperature for all cores.
So it's physically not possible to get per-core temperature reading on those CPUs.
I would recommend: HWiNFO32.
My stuff
PhII x6 1055T @ 4.2GHz | Corsair H50 + Scythe SL12SH PnP | Asus Crosshair IV F | 4GB Dominator 1600 CL8 | Corsair HX520W | CM HAF932 | Dell 2405FPW | Creative 5.1 THX |
HWmonitor is fine for me and my 1055T.
Regards
Unknown_Team / Owner-Founder and Overclocker.
Round up 4 Coolers-Thermalright-Thermaltake FRIO-Noctua
great info thanks guys.
Intel I7-3770K
Asus Sabertooth Z77
Mushkin 240 SSD
EVGA GTX 680
Xspc RX360 Rad
Xspc XS360 Rad
2 x Mcp 350 Pumps
i normally offset to 5c below the IHS at full stock load
so the thuband only have 1 die sensor, why would amd do that the denabs and their derivatives had 4 sensors didnt they. and that would explain why they always read the same temp as that had baffled me
Use PC Probe mate - comes free from Asus with your motherboard and also displays the correct cpu temp
4960X@4.7 | Asus RIVF | 16Gb@2400 | 256Gb 840 Pro | R9 290 | AX-860W | 540Air | Custom W/C
On my 1090T, everest claims that the CPU is at 25º while the water that cools it is currently at 32... I don't think any program can read the Thubans temperature correctly :/
ASUS Sabertooth P67B3· nVidia GTX580 1536MB PhysX · Intel Core i7 2600K 4.5GHz · Corsair TX850W · Creative X-Fi Titanium Fatal1ty
8GB GSKill Sniper PC3-16000 7-8-7 · OCZ Agility3 SSD 240GB + Intel 320 SSD 160GB + Samsung F3 2TB + WD 640AAKS 640GB · Corsair 650D · DELL U2711 27"
