+ Reply to Thread
Results 1 to 6 of 6
Thread: Problem!
    Xtreme Enthusiast breathemetal's Avatar
    Oct 2008
    Flint, MI
    1
    Problem!
    So i just got a Kinetic 5.1 system for free, i know its not the best of systems, but its better than my tv's speakers, ha, and its surround at least!
    Anyways, here's my dilema.
    It's a bit older, so no HDMI or no Component, just Composite (RWY) hookups
    What can i do here to hook this up to my Bluray and get full surround?
    Im a bit new to this whole thing.
    I have a cheap Magnavox bluray for now btw
    It is the Kinetic KA-4210 system but w/ KA-5500 towers as the fronts and 4210's as the rears. From what i can tell, it was a pretty pricey system, but idk.
    Upon further investigating, it looks like these seem to be "white van" scam speakers, as in asian junk.
    Well, idc, i got em free haha, and they sound better than my tv's speakers.
    Oct 2008
    Flint, MI
    1
    Anyone?
    I am Xtreme Donnie27's Avatar
    Jul 2004
    Little Rock
    2
    Quote Originally Posted by breathemetal View Post
    Anyone?
    With a set top blue ray you can't do anything. HDMI acts as the Blueray's first line of DRM (Defense as they see it). The best analog you'll get is Stereo. The Coax or Optical out should allow DTS or DDL.
    The other way around this is adding a Blue-ray to you HTPC and then use your Analog out. I use PowerDVD 9 With BD support.
    Quote Originally Posted by Movieman
    With the two approaches to "how" to design a processor WE are the lucky ones as we get to choose what is important to us as individuals.
    For that we should thank BOTH (AMD and Intel) companies!
    Posted by duploxxx
    I am sure JF is relaxed and smiling these days with there intended launch schedule. SNB Xeon servers on the other hand....
    Posted by gallag
    there yo go bringing intel into a amd thread again lol, if that was someone droping a dig at amd you would be crying like a girl.
    qft!
    Xtreme Mentor Nanometer's Avatar
    May 2005
    Westlake Village, West Hills
    4
    your best option is optical out which is what was already mentioned. Otherwise you kind of are SOL, optical out does not transfer 6 separate channel to my knowledge which is exactly what surround sound requires.
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
    Xtreme Cruncher werdwerdus's Avatar
    Feb 2009
    Iowa, USA
    19
    optical or coax digital WILL output 5.1 if it is dolby digital or DTS. but i doubt the speakers have a decoder built in.
    Main: i7-930 @ 2.8GHz HT on, 2 threads WCG; 2x EVGA GTX 470 100% GPUGrid
    2nd: i7-920 @ 2.66GHz HT off, 3 threads WCG; 1x EVGA GTX 650 100% GPUGrid
    3rd: i5-3570k @ 3.61GHz, 2 threads WCG; 2x GIGABYTE GTX 660 Ti OC 100% GPUGrid
    4th: i5-3570k @ 3.61GHz, 2 threads WCG; 2x GIGABYTE GTX 660 Ti OC 100% GPUGrid
    5th: i3-530 @ 2.93GHz HT off, 1 thread WCG; 1x XFX Radeon HD 7850 100% Donate@Home
    6th: i7-3770k @ 3.70GHz HT on, 3 threads WCG; 2x GIGABYTE GTX 660 Ti OC 100% GPUGrid
    Part-time: FX-4100 @ 3.6GHz, 2 threads WCG; 1x EVGA GTX 650 Ti SSC 100% GPUGrid
    Jul 2004
    Little Rock
    2
    For those who think Piracy is OK, this is an extreme version of what happens with Copy Right Infringement. All of the arguments like; "Nothing was stolen, they lost nothing so it is OK" is BS. Incidents like this pretty much prove what is wrong.
    The company makes great stuff. A friend's uncle left a her a mid sized set that will give B&W, Klipsch and anything else on the AVS forum a run for the money.
    The real Company.
    http://www.kineticaudio.com/
    They are known by the elongated K and do make sweet products.
    But they have a "Swappmeet" version like the ones Breathmetal got, glad he didn't pay anything
    http://www.brighthub.com/electronics...les/50513.aspx
    The first fakers
    http://www.kineticloudspeaker.com/
    Then they supposedly have fakers of the fakers made in China that aren't crossover correctly, aren't balanced (bad Ohm loads), and have a tendency to mess up Sound systems. I got an online friend who switched out speakers with drivers from Ebay and Parts Express because as he said his wife liked the way they looked. She got scammed in a Wal-Mart parking lot. I didn't say anything because BM already explained.
    If it is too good to be true, more times than not, it isn't true. Geesh guys, paying $175 for $3500 ain't goin' to happen.
    Their Logo is known better than their name.
    http://www.kineticaudio.com/images/im1.jpg
    Posted by duploxxx
    Posted by gallag
    qft!
+ Reply to Thread
