Occasionally I get back to my PC, and the GPU fan is much louder than it should be at idle. I check what is going on with afterburner, and it looks like this:
I can't manually bring the voltage back down, and have to restart the computer. I am fairly sure it has only been happening within the last month or so, and it has only happened ~3-4 times.
I modified the bios so that it underclocks the card, and doesn't get ridiculously hot and loud when running dual monitors. I overclock it to 830/1200 at stock volts each time I play games.
Any ideas what the problem could be? Pretty sure 1.65v is kinda dangerously high?
