Oh I see it is you clouding the issue....it is more normal to quote the Qmax than the max consumption.
If they are 12709's the spec sheet I quoted is correct...they are 12709's.
here it is again:-
http://www.customthermoelectric.com/...W_spec_sht.pdf
The actual power draw will depend heavily on your Dt. As your linking multiple TECs 0.25 amp either way can make a lot of difference to the outcome especially when undervolting as you can see from the sheet.
At 4v you will be forcing the initial Dt low (10-20) range which of course requires more current, and the cooling wattage would drop below 30w
At 6v the difference in Dt is not so great. You should still expect to initially be in the low 20's - top 10'.
I say initial Dt because that is what it is - it is determined initially by the power level the Dt is further altered by the load you apply to the coldside relative to it's Q at that operating point.
Spec sheets are really only for ballpark figures to determine operating points not for accurate determination of any figure.
The only way to get accurate figures is to run the TEC at your determined operating point.
