I just picked up a i7 930 at a decent price.
Only if there was a microcenter near me, I would be there everyday and be broke lol...
[i7 4770K] [Z87 Gene VI] [8GB Sammy] [GTX780] [H80i] [AX850] [350D] [XL2720T]
The 950 is pretty tempting too at only $30 more...
X5670 B1 @175x24=4.2GHz @1.24v LLC on
Rampage III Extreme Bios 0003
G.skill Eco @1600 (7-7-7-20 1T) @1.4v
EVGA GTX 580 1.5GB
Auzen X-FI Prelude
Seasonic X-650 PSU
Intel X25-E SLC RAID 0
Samsung F3 1TB
Corsair H70 with dual 1600 rpm fan
Corsair 800D
3008WFP A00
I would say the 950 as you have a nice 24 multiplier to play with as opposed to the 22 max multi on the 930....
With the 24 multi you are much less likely to be bclk limited
Most boards max out the bclk at 210 - 222 so for example with 24 x 222 you have more overclocking headroom than with 22x 222
EVGA GTX 580 1.5GB
Auzen X-FI Prelude
Seasonic X-650 PSU
Samsung F3 1TB
Corsair 800D
3008WFP A00
I <3 not having a MC even in the same state as me.
Core i7 920 D0 B-batch (4.1) (Kinda Stable?) | DFI X58 T3eH8 (Fed up with its' issues, may get a new board soon) | Patriot 1600 (9-9-9-24) (for now) | XFX HD 4890 (971/1065) (for now) |
80GB X25-m G2 | WD 640GB | PCP&C 750 | Dell 2408 LCD | NEC 1970GX LCD | Win7 Pro | CoolerMaster ATCS 840 {Modded to reverse-ATX, WC'ing internal}
CPU Loop: MCP655 > HK 3.0 LT > ST 320 (3x Scythe G's) > ST Res >Pump
GPU Loop: MCP655 > MCW-60 > PA160 (1x YL D12SH) > ST Res > BIP 220 (2x YL D12SH) >Pump
i7-3930K
GA-x79-UD3
Corsair H100
4x2GB F3-12800CL6
X-Fi Xtreme Music
EVGA GTX 470
Pioneer BDR-207DBK
2X128GB Samsung 830's
3XWD2002FYPS
Corsair TX850
Dell U2412M
___________________
Hows the 950 Ron?
MV-G
3770K 5.00
7970 1200/1700
GSkill 2400
Seasonic Platinum 1000
Silverstone TJ08-E
- Koolance AC-370 - Swiftech MCP-35X - Phobya Xtreme 200mm Rad - Koolance VID-AR797 -
USA National Debt
Walker is going to let me have (use) one of his 980s to test out. When you and I were talking it made me think I would rather have the 980 so I held off.
they also have a banchetto 101 for 80 bucks!!!
I picked up a 950 today that was a "F" batch. Haven't had time to play with it, but default vcore is 1.11v, so it looks promising.
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Desk Build
FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
W/C System
(CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
can someone pick me up a 950?? PM me if so!
1
