I'm running G42 bios. Here are the settings below. I'm running all stock volts except for VTT, which is +20mV. Right now I'm 12 hour prime stable. I want to bump up the bclk up to 200 and be 12 hour prime stable.
I tried bumping up the bclk to 195 and core voltage to +80mV (1.33v), QPI up to +80mV, and DRAM up to 1.65. It fails 5 minutes in.
Besides cpu voltage, vtt voltage, and ram voltage, what other voltage increases help with hitting 200 bclk?
Here's the rest of my specs:
i7 920 d0
Foxconn Bloodrage
6 GB OCZ Platinum 1600 @ 7-7-7-24
Sapphire 4890 Vapor-X
X-Fi Titanium Fatal1ty Pro
Corsair 620HX
Viewsonic vx2255wm 22" LCD widescreen
Lancool PC-K62
7 64-bit Ultimate
CPU Features
PPM ......................................: Enabled
EIST .....................................: Enabled
CxE........................................: Disabled
Execute Disable Bit ..................: Enabled
Virtualization...........................: Enabled
CPU Write Back Cache ..............: Enabled
Hyper Threading ......................: Disabled
Active Processor Cores .............: All
Current Feedback Override ........: Enabled
CPU QPI Latency .....................: Auto
IOH QPI Latency ......................: Auto
CPU QPI Drive Strength .............: Auto
IOH QPI Drive Strength .............: Auto
Memory Settings
Memory Controller Settings
IMC Configuration ....................: Enabled
Channel Congifuration ..............: Independent
Channel Interleaving ................: 6 way
Rank Interleaving ....................: 4 way
Memory Timings
Virtual XMP .............................: Disabled
DRAM Timing Control .................: Manual
Current Timings .......................: 7-7-7-24-1-60-8-14-4-4
tCL (CAS Latency) ...................: 7T
tRCD (RAS to CAS Delay) ...........: 7T
tRP (RAS Precharge) .................: 7T
tRAS (Precharge Delay) .............: 24T
CR (Command Rate) ..................: 1T
tRFC (Refresh Cycle Time) .........: 60T
tWR (Write Recovery Time) ........: Auto
tWTR (Write to Read Delay) .......: Auto
tRRD (RAS to RAS Delay) ...........: Auto
tRTP (Read to Precharge) ..........: Auto
B2B CAS Delay .........................: Auto
All Voltage Settings
CPU Voltages
CPU Core Voltage ....................: Default
CPU Target Core Voltage ...........: 1.25625V
CPU Vdroop Compensation .........: Disabled
CPU VTT (UnCore) Voltage ........: +20mV
1.8 PPL Voltage Setting ............: 1.800V
CPU Clock Amplitude Ctrl ...........: 0.800V
Memory Voltages
DRAM Voltage .........................: 1.60V
DIMM1 Vref CA (Addresses) .......: x 0.500
DIMM1 Vref DQ (Data) ..............: x 0.500
DIMM2 Vref CA (Addresses) .......: x 0.500
DIMM2 Vref DQ (Data) ..............: x 0.500
DIMM3 Vref CA (Addresses) .......: x 0.500
DIMM3 Vref DQ (Data) ..............: x 0.500
Chipset Voltages
X58 IOH Core Voltage ..............: 1.10V
X58 IOH VCCA 1.1V .................: 1.108V
X58 IOH VCCA 1.5V .................: 1.506V
ICH10 SB Voltage ....................: 1.506V
OC Gear
Smart Boot Menu .....................: Disabled
Smart Power LED .....................: Disabled
Auto Detect PCI Clock ..............: Enabled
Spread Spectrum .....................: Disabled
CPU Clock Skew .......................: 0ps
IOH Clock Skew .......................: 0ps
Over Clock Recovery ................: Enabled
CPU Turbo .............................: Enabled
System Turbo ........................: Enabled
Clock Speed Control Center
CPU Bclock (FSB) ....................: 189MHz
QPI Link Fast Mode ..................: Enabled
QPI Multiplier ..........................: x18
CPU Core Multiplier ..................: x20 (21)
CPU Uncore Multiplier ...............: x16
Memory Bus Multiplier ...............: x8
PCI Express Bus Clock...............: 100MHz
