+ Reply to Thread
Results 1 to 19 of 19
Thread: What psu's are WC ers choice?
    Xtreme Member Neutronman's Avatar
    May 2010
    Vegas
    0
    Perhaps I should post elsewhere but as my power supply fan seems to be the loudest part of my watercooled setup these days perhaps you guys can suggest quiet psu at load ? Preferably as loud as GT 1850's, single rail and modular?
    Thanks,
    I am Xtreme BeepBeep2's Avatar
    Jan 2009
    Ohio
    361
    Corsair AX850/Seasonic X-Series 850 would be perfect for you.
    Xtreme Enthusiast leo_bsb's Avatar
    Aug 2007
    Brasilia - DF - Brazil
    13
    corsair 850 HX, basically has the same AX850/seasonic X/OCZ gold efficiency for less money.
    My Lian Li G70
    Asus P6X58D-E * i7-930 * Saphire 7970 * 6GB Corsair XMS3 1600 C7 * Crucial M4 256GB SSD * Lian Li G70W Powdercoated
    Watercooled by single loop Coolgate Quad 120 + Swiftech MCR220 with San Aces H1011 * EK Supreme HF * Koolance VID-AR797 * EK Asus X58 full set * DDC 3.25 with EK Dual Top/Res
    Jan 2009
    Ohio
    361
    Quote Originally Posted by leo_bsb View Post
    No, not in any way. But I would take that over the OCZ Z-Series, that stuff is nasty. I'd stay away.
    Feb 2009
    Montreal
    2
    I'm running a seasonic x-750 (the biggest gold rated psu i could buy back this summer) and now I'd do either that or ax-1000.
    Xtreme Cruncher meanmoe's Avatar
    Aug 2009
    Huntsville, AL
    6
    Seasonic X-series for anything special and cheapy antec greens for those not so special...
    upgrading...
    Xtreme Addict ScottALot's Avatar
    Feb 2010
    Wisconsin
    2
    PC Power and Cooling 750W, XFX 750W, XFX 850W
    Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
    Xtreme Addict Boulard83's Avatar
    Mar 2009
    1
    TPQ-1200 OC
    You cant go wrong !
    - Le Quebecois -
    - - - BTTB - - -
    EVGA X79 FTW - I7 3820 - PH-TC14PE - 16gb G.Skill 2133mhz - EVGA GTX 670 + Accelero TTII
    Tecnofront HWD BenchTable - Antec TPQ-1200-OC - 2x Agility 4 256gb - Surround Asus VE278Q 5760x1080
    - - - HTPC - - -
    Asus Z77-m Pro - 2500K - NH-C12P - 2x4gb G.Skill Ares 1600mhz
    Asus GTX 650 TI - X25-M 80gb - Enermax Naxn 550w - Lian Li PC-C60B
    - - - NAS/Server - - -
    Gigabyte H77m-D3H - G2020 - 2x4gb G.Skill 1600mhz - 2x 1TB Black - 1x 2TB green - CX430M
    Forum Quebecois, si tu parles francais !
    Aug 2007
    13
    Quote Originally Posted by BeepBeep2 View Post
    hmmmm, let's check what jonnyguru said:
    http://www.jonnyguru.com/modules.php...tory2&reid=153
    850 HX cold peak efficiency: 90.1%
    850 HX hot peak efficiency: 90.6%
    http://www.jonnyguru.com/modules.php...tory3&reid=197
    AX 850 cold peak efficiency: 89.5 %
    AX 850 hot peak efficiency: 89.6 %
    so, yeah, more efficiency for less money
    I knew that because I did my research and just bought one.
    My Lian Li G70
    Xtreme Enthusiast MagisD's Avatar
    Mar 2009
    Toronto ON
    1
    Huh nobody's mention the current favorite for build logs the ax1200.....still waiting for mine on backorder
    Sent from my X10a using Tapatalk
    MagisD
    ____________________________
    Lurker, Dreamer, Planner, Noob
    6 Quad rads 1 case Maybe I went a little overboard....Overkill Cube
    Jan 2009
    Ohio
    361
    Peak /= efficiency as a whole. The HX850 holds 90% from ~350-500w where it then drops to 86.1 from there and finally down to 84.9. The AX850 holds 87% up till the last test when it's at 85.6%.
    Not just that, but efficiency does not make a PSU. The AX850 is quieter, and doesn't get as hot. It hardly puts out heat at all. Just look at the exaust temps in both reviews from the cold box.
    NOT just this, but these PSU's were reviewed by two different people, with different equipment, and different power meters. For all we know, there is a 3% error tolerance. Ripple seems to be suppressed better (not that it matters at this point) on the AX850 as well.
    HX850 is manufactured by Channel Well Technology while the AX850 is manufactured by Seasonic. The HX850 is only half modular, while the AX850 is fully modular. They are not even remotely the same PSU.
    Aug 2007
    13
    read my first post: I never said "the same PSU". I said "basically the same efficiency for less money". the HX hold up pretty well with 84% efficiency at the lower score.
    They may have changed equipment or tester, but a LOAD is a LOAD, isn't it? And the temperatures are not comparable since the intake temperature on the HX tests are not the same. It seems that the HX passed more severe condition tests than the AX.
    Are you kidding about the "fully modular" right? Are you able to run your computer without the ATX cable and PCI-E for one video card? These are the non modular cables on the HX, the ones you always use.
    The other differences are even less important: noise was described as "The unit stayed pretty quiet, even in the hot box" and " the fan produced virtually no noise". Manufacturer does really count as an advantage?
    Whatever, it is just my opinion. IMHO the HX is a better bang for your buck compared to the AX
    My Lian Li G70
    I am Xtreme Hondacity's Avatar
    Aug 2008
    110
    awesome stuff lea_bsb
    hx is better than ax....voltage regulation wise ...id go hx850 over ax850 anytime and cheaper too....
    about efficiency at max load....who does that? lol
    Mar 2009
    Toronto ON
    1
    Huh as i understand it if your running you ps at max load your doing something wrong.
    So its oranges vs tangrines.
    MagisD
    Xtreme Member phantomferrari's Avatar
    Feb 2007
    8
    anyone know when the seasonic x 850 is going to be released? im guessing it will have very similar performance with the corsair ax 850
    Xtreme Member USFORCES's Avatar
    Sep 2006
    4
    Water cooling choice would be a Liquid-Cooled Koolance 1300w
    Or the 1000w http://www.performance-pcs.com/catal...ducts_id=26347
    May 2010
    Vegas
    0
    Interesting stuff guys, I am really interested in affordable, quiet cooling. I guess I see two real choices for me either the Channel Well HX 8500 from Corsair or the XFX Black Edition 850W Sea Sonic unit, my only concern with the Corsair is the crappy modular pci-e cables and with the XFX the Adda fan.....
  18. #18
    Sep 2010
    0
    Seasonic X-750. I run a fanless system bar the fan in the psu and it rarely even spins and even when it does it runs so slowly it's inaudible. Would probably be different if it was running at near it's capacity though. Highly recommended.
  19. #19
    Xtreme Mentor Utnorris's Avatar
    Sep 2007
    Dallas
    11
    Quote Originally Posted by Neutronman View Post
    You want a cheap, but decent PSU, how about this:
    https://www.geeks.com/woot/
    Thread about them:
    http://hardforum.com/showthread.php?t=1548877
    If you do not care about a warranty this is a pretty decent deal, plus you could always swap out the fan since there is no fear of losing your warranty.
    CPUID http://valid.canardpc.com/show_oc.php?id=484051
    http://valid.canardpc.com/show_oc.php?id=554982
    New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
    4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
    Desk Build
    FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
    W/C System
    (CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
+ Reply to Thread
