Results 1 to 5 of 5
Thread: Clock Skew?
    Jan 2009
    Tournaments Joined
    0
    Tournaments Won
    0
    Clock Skew?
    CPU Clock Skew
    IOH Clock Skew
    What are these 2 options for in the bios?
    Jan 2010
    Tournaments Joined
    0
    Tournaments Won
    0
    They allow you to delay or speed up the clock signals. Some use slight delays (200-300ps) and claim enhanced overclocking ability/stability.
    Personally I haven't found a need to touch it or any benefit from it.
    Apr 2010
    Bulgaria
    Tournaments Joined
    0
    Tournaments Won
    0
    CPU Clock Skew helped me with my old CPU, it was unable to do 216 BCLK, + 100 ps did the job. But not much than this. Increasing it further gave me instability. I guess these two work with conjunction, and both values must be matched to achieve something better.
    Foxconn BloodRAGE GTI|i7 920(200x21)|6GB Kingston HyperX 1866 CL9(1600 6-7-6)|GTX 470 SLI|WD300HLFS|CM Silent Pro M850
    AsRock X58 Extreme3|i7 920(212x19)|6GB Kingston HyperX 1866 CL9(1700 7-7-7)|GTX 460 768 MB|WD300HLFS|Audigy|Chieftec CFT-650-14C
    AsRock P67 Extreme4|i7-2500K(45x100)|2x2 HyperX Genesis 1600(1866 9-10-9)|2xGTX 460 768 MB|RAID1 2x1TB Т7K1000.C + WD6401AALS|CM Silent Pro 600
    Aug 2010
    Tournaments Joined
    0
    Tournaments Won
    0
    Exactly:
    Quote Originally Posted by MagicBox View Post
    You have any clock delays set? Either CPU or IOH skew? Setting those to a 'wrong' value can have that effect. I leave those to the defaults as that seems to be the most stable anyways, these settings come into play when you want to push your BCLK hard, which 200 isn't.
    Quote Originally Posted by PiLsY View Post
    OC Gear :
    Spread Spectrum ..................: Disabled
    CPU Clock Skew ...................: 100ps Really helps over 4.5ghz
    IOH Clock Skew ...................: 0ps
    3) CPU and IOH skew of 200-400 ps helps me stabilize at over 220 bclock. Also, it is more stable if I make their skews equal to each other, rather than offset at all. Even with P06 BIOS, I got more stable benching above 4.5 GHZ with the skews at 100 ps.
    4) Contrary to the P06 BIOS, the G25 seems to like the Aegis Panel more for OS overclocking than setfsb.
    Quote Originally Posted by Lord Trident View Post
    this may help some people
    set QPI DRIVE strength 10-25 and the QPI latency to 100.
    It will help you to get more FSB.
    before you ask no i dont know got this from the engineers so give it a try
    have fun
    thanks
    ASRock 990FX Extreme4|AMD FX-8320 w/water|OCZ3RPR1866C9LV4GK|XFX HD5850|WD6000HLHX|PC P&C Silencer 910W
    Foxconn BloodRAGE X58|Intel Core i7 920|G.Skill F3-16000CL9T-6GBTD|XFX HD5770|WD6000HLHX|PC P&C Silencer 750W
    Nov 2008
    Heart of Europe
    Tournaments Joined
    0
    Tournaments Won
    0
    It helps in higher end of OC. I wouldnt be able to reach 4,6 GHz without playing with this..
    Downside is, that as efficiency goes, it slows PC down a bit. At least happened to me, so for SuperPI runs and such, not usable. Though QPI drive strength and mild clock skew (100ps) might help.
    i7 930 D0 - 4,2 GHz + Megashadow
    3x4GB Crucial 1600MHz CL8
    Foxconn Bloodrage rev. 1.1 - P09
    MSI HAWK N760
    Crucial M500 240GB SSD
    SeaGate ES.2 1TB + 1TB External SeaGate
    Corsair HX 850W (its GOLD man!)
    ASUS STX + Sennheiser HD 555 (tape mod)
    Old-new camera so some new pics will be there.. My Flickr My 500px.com My Tumblr
