Results 1 to 3 of 3
Thread: blodrage gti and new Intel® Rapid Storage not work
    Jan 2008
    Unhappy blodrage gti and new Intel® Rapid Storage not work
    my blodrage gti (bios g42) and beta rapid storage http://www.station-drivers.com/page/intel%20raid.htm ( 10.0.0.1043 ) not work, my system windows 7 x64, how to get it to work, sorry bad language, my english very bad
    May 2007
    Tried the previous 10.0 beta, and that was a total failure, the 10.0.0.1043 beta arrived shortly after, and are working properly, allthough I only installed the driver not the software and on a FlamingBlade X58...
    Try a driverinstall only, extract the files and update manually via device manager.. If it's still messing up for you, don't worry, there is no point in updating to this one unless you are on raid0.. Generally be very carefull with storage controller beta drivers, as they may destroy your data and ruin your OS install...
    | Ci7 2600k@4.6ghz | Asus SaberTooth P67 | Sapphire HD7970 | Samsung B555 32" | Samsung 840 PRO 128gb + 2xIntel SSD 520 120GB Raid0 + 2xC300 64GB Raid0 | Corsair Vengeance 16GB DDR3-1600 8-8-8-24 | Vantage GPU=40250 |
    Xtreme Mentor dengyong's Avatar
    Nov 2006
    A great place again
    I'm using this driver only, on a full bloodrage (P09 bios) with a single G.SKILL Phoenix Pro 120GB. It works well and boots noticeably faster.
    First extract with winrar...
Tags for this Thread
