+ Reply to Thread
Results 1 to 3 of 3
Thread: EVGA nForce 730a AM2+ problem
    Xtreme Member desnudopenguino's Avatar
    Aug 2009
    Somewhere
    2
    Hey. I have come across an interesting problem with one of these motherboards... I was running my 550BE in it, since it is an AM2+ board, and it was running fine, then I think my power supply started getting retarded. I would have to press the power button a few times before the computer would stay on. And eventually the PSU flat out stopped working (the POST time was over 990 ms or whatever it is for good PSUs). Now when I try to boot up this motherboard, the onboard LED shows a bunch of nonsense. The segments that light up don't make any sort of hex code. Does anybody know what might have happened and how to remedy this? I bought it from a guy on ebay, so I'm not taking a big hit if it is dead, but I was wondering if there was some way to fix it before I passed it on to the recyclers.
    Thanks,
    Bucky
    Desktop (and Cruncher #1):AMD Phenom II x6 1090T @ 4.03Ghz | Gigabyte MA790FXT-UD5P (F8n) | G.Skill Ripjaws 2x4GB @ 9-9-9-24-1T 1680MHz | Radeon HD 5850 & 5830 | Silverstone ST75F 750W | 60GB OCZ Vertex 2 3x1TB WD RE3 (Raid 5) | Lian Li PC-A70B
    Cruncher (#2): Intel Core I7 920 (stock) | EVGA X58 SLI | G.Skill Pi 3x2GB | 2x Radeon HD 6870 | Corsair HX850 | Some Janky HDD | LanCool PC-K7
    Cruncher (#3): Intel Core I7 2600k (stock) | BioStar TH67+ | G.Skill Ripjaws 2x4GB | Antec Basiq550 | Some Janky HDD | Antec 300
    Server: Intel Atom | 2x2GB DDR3 | ThermalRight TR2-430 | Some Less Janky Laptop HDD | Fractal Core-1000
    Mobile: Lenovo X120e
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    20
    the chipset most likely desoldered its self, NV likes to do do that
    3770k, M5E, kingston 2x4GB cfr
    samsung 2TB F4EG, samsung 840 250GB , CM690II, corsair 750tx
    Aug 2009
    Somewhere
    2
    Hmm... Is there any way I could test this? Pushing on the chipset to see if it makes a good connection? sounds like it might be a fun project... what do I have to lose?
+ Reply to Thread
