Page 1 of 2 12 LastLast
Results 1 to 25 of 45
Thread: Fan Testing Commencing GTs vs Noctua vs Silverstone vs Yate
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    First, a very special thanks to the following people for sponsoring this upcoming Test:
    Gentle Typhoon AP-15 - Hondacity
    Noctua P12 - Masika
    Silverstone AP-121 - MagisD
    Thanks guys
    And the contenders and Tools:
    I plan to simply employ HD video recording from my Canon T2I and run the fans through their voltage sweeps, also stopping specifically at 10,20,30cfm increments for a spectrum noise profile comparison.
    Will we have a new king?? The blade densities look promising. Any guesses?..
    I'll share something by the end of the weekend for your perusal..
    Cheers!
    Martin
    Attached Images Attached Images
    Feb 2010
    UW - Madison
    Are you measuring airflow through the radiator too?
    Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Quote Originally Posted by ScottALot View Post
    Are you measuring through the radiator too?
    Yes, it will be testing through the radiator. The entire test will compare noise qualities vs radiator air flow. My anemometer vane probe is on the outlet side of my radiator box.
    There are plenty of open air tests out there, I prefer focusing on the radiator performance since it makes such a huge difference.
    This is the video framing I'm thinking of...something similar to this:
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Anyhow, if you have any suggestions...now is the time..
    As usual, these tests can only happen in the wee hours of the morning in the darkest quietest corner of my bedroom closet...so I figured I'd try to either run them tonight or tomorrow night and start uploading videos/results Sunday.
    Feb 2008
    Belfast NI
    You know you couldnt have picked a better moment to do this.
    There was a guy on another forum asking Nocutas vs GTs.
    Now we will be able to get a definitive answer.
    Thanks Martin!
    ASUS Rampage II Ex 1504
    Intel i7 920 D0 3850A795
    Sapphire HD5970 EK FC 1Ghz/1150Mhz 1.237v
    OS Intel X25-M RAID0
    Data 500GB Seagate Barracuda 7200/32Mb
    OCZ Reaper 6GB/1800/C8
    BeQuiet Dark Power Pro 1200w
    1X 18w DDC3.2 w/XSPC Res Top
    1X 18w DDC3.25 w/XSPC Res Top
    1X XSPC Submersible Pump/Res w/RS120mm
    HW Labs GTX480 4x120mm
    TFC Monsta 6x140mm
    EK Supreme LT 3/8" Feser Tubing
    EK IOH/SB and Mosfet Blocks
    Lian Li V2110 w/EX-34
    26" Iiyama Prolite
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Yeah, I'm pretty excited about this one. These two fans seem to have some unique fin shape/densities. I've always wanted to try a Noctua since my first round of tests...would be nice to have some good competition against the GT with it's supply problem..
    Aug 2010
    San Jose, California
    I'm looking forward to your results. I thought the soundmeter on your phone was a cool idea.
    The comparison will be nice since it seems like every online store I use has been out of GTs for awhile now.
    Apr 2008
    Ottawa, Canada
    Bravo! Nice setup for testing. Looking forward to results. Thanks again Martin!
    Feb 2010
    UW - Madison
    Definitely keep that setup and do more fan reviews! I really enjoy the setup.
    Jan 2008
    very much looking forward to this
    Banned
    May 2010
    France
    Great test
    Can you compare water temperature at a given dB level? I'm not sure you'll get enough air at low speed for your anemometer
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Quote Originally Posted by kroks View Post
    Great test
    No, not thermal testing...that would take way too long. Since my last round I did purposely reduce the opening to my flow chamber outlet. This has given the anemometer.
    That's the cool thing about the anemometer, you can calibrate it for different duct sizes. It does have a minimum air speed, but you can tweak the duct size way down if you're interested in looking at very low flow rates.
    Since my last round I've done just that, so I'm able to read a bit lower CFM levels..
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Thanks guys...hope you like the new video formats when they are done.
    Great test
    No, not thermal testing...that would take way too long. Since my last round I did purposely reduce the opening to my flow chamber outlet. This has given the anemometer. So I am sticking with the air flow based testing for now, but I'm open to some playing around with stuff like shroud testing and push/pull noise comparisons..etc. Those sorts of things are of interest to me. Masika was gracious enough to donate for two P12s, so I plan to at least test the P12s in a push/pull setup after this initial round.
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    I also have these new Rosewill fans I pulled out of a Rosewill Challenger case I just bought for my son's computer (Budget build using mostly old parts I had lying around). Considering you can buy similar models for a little as 4 fans for $10 ($2.50 each), and since I already had them, I figured I'll throw these into the round as well. I'll look for two categories of winners, the best cfm/noise fan and the best budget fan..
    It's only fitting of my budget build I'm working on...if they work well, I may buy some more. Never thought there would be a fan that's cheaper than a yate loon, at $2.50 per fan that 10X less than the P12s that cost $24 each..
    We'll see how they do..I kind of like the clear minus the LED part, nice smooth blade surfaces for such a cheap fan.
    Admin
    Feb 2005
    Ann Arbor, MI
    Looking forward to this
    I'm guessing the Gentle Typhoon wipes the floor with the other three, but maybe the AP121 will surprise. I wonder if removing the majority of those air directing blades on the AP121 would improve performance on a radiator.
    Mar 2009
    Toronto ON
    Chop that ap-121 up in the name of science if you have to. ...i just want destruction shots lol....
    Sent from my X10a using Tapatalk
    MagisD
    ____________________________
    Lurker, Dreamer, Planner, Noob
    6 Quad rads 1 case Maybe I went a little overboard....Overkill Cube
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    If it doesn't perform well I will...
    Have dremel, will sacrifice!
  18. #18
    Admin
    Feb 2005
    Ann Arbor, MI
    Here's to hoping
  19. #19
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Figured anything you call a "Round" ought to have a proper weigh in..
    If weight has anything to do with bearing/motor quality, the GT is looking pretty good.
    Interesting how the acrylic rosewill fan is lighter(I guess it makes sense), curious what that means (if anything) for noise. I was pretty happy with the old clear yate's noise qualities, unfortunately it was so low in RPM...you couldn't really test it.
    Anyhow, the weigh in is done...the contestants are warming up in their respective corners.., unfortunately there are no weight classes here..lightweights..heavyweights..all go head to head..
  20. #20
    Admin
    Feb 2005
    Ann Arbor, MI
    Gotta say I'm rooting for the Rosewill Black now that I see the two newest additions
    Don't like LEDs but I do like low prices, and I do like NewEgg (Rosewill is their house brand), so go Rosewill!
  21. #21
    Feb 2010
    Northern California
    i would be interested to see how older fans that i used to use for wcing compare to new fans, lol also interested in those rosewill !
  22. #22
    I am Xtreme
    Aug 2008
    oh nice....welcome back to testing..
  23. #23
    Aug 2010
    Norway
    Ahh, what better way to start the day than fresh review charts! Can't wait for the results
  24. #24
    Feb 2009
    You are the man, Martin!
    BTW, do you work as an engineer or something? I swear the first time I started looking at your analysis I could not understand of it
    Quote Originally Posted by NKrader View Post
    im sure bill gates has always wanted OLED Toilet Paper wipe his butt with steve jobs talking about ipad..
    Mini-review: Q6600 vs i5 2500K. Gpu scaling on games.
  25. #25
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Quote Originally Posted by prava View Post
    Thanks, yes..I'm a civil in transportation(not related at all to this stuff), and that makes two of us.. I don't know what the heck I'm doing either, just experimenting and learning as I go..
    FYI, I got the videos & audio recorded last night and working on combining them. Should have some videos to share later this evening or tomorrow.
    I'll start looking at the numbers after the videos go up and create some charts.
