+ Reply to Thread
Results 1 to 6 of 6
Thread: Ok, I'm retarded, but just thinking about NF3 250, what will they give us?
    Xtreme Addict JNav89GT's Avatar
    Oct 2002
    IL
    0
    I mean if we have to neuter the HT/LDT anyway to oc the fsb will the NF3 250's really be much better. Ok, they may iron out bugs of the boards(but those aren't that bad now).
    I see the biggest advantage as being hopefully locked PCI buses as I think we've all seen the current NF3 while certainly more tolerant of oc'ing than the via, isn't locked NOW.
    My other question re: NF3 250 would have to be due to my ignorance of this whole mainboard architechture: Will having the true 800mhz HT at default allow for higher FSB before we do have to neuter the HT/LDT buses. For example, say now you have to go to 2.5LDT at say 220-230fsb. Will be be able to run at say 3x LDT on the 250 boards up to even 250fsb :O
    Or, is LDT/HT abilities directly tied to the cpu and therefore not really a function of the board really other than baseline support. :O
    I have a headache now
    it's never fast enough!
    Xtreme Addict Riska's Avatar
    Apr 2003
    Denmark
    0
    If i am correct the biggest differens is dual channel memmory!
    The man with the littel Barebone!
    And proud Crew of!!!
    Octeamdenmark.com
    Shuttle SX38P2Pro Barebone E8600cpu and HD4870X2 gfx and 2gig Crusial Ballistix PC8500 Cl5 and 2x150gig Raptor in raid 0 and 1x750 gig seagate
    Msi 790FX-GD70 Mobo Amd 955-965 PHII cpus and 2gig Crucial value PC10600@800mhz 7-5-5-15 1T
    And 4x500GB Seagate 7200.12 in raid0
    4xHD5770 in CFQ.
    Xtreme Addict luihed's Avatar
    Jan 2003
    0
    I dont think its got anything to do with dual/single channel, 754pin will stay single channel and 940pin will stay dual on the nf250 boards....... I think its got something to do with having 4x ldt at default speed ala via......
    E8400 DFI LP P35T2R Ballistix
    8800GTS PCP&C 1.2kw Raptors
    E6600 =5400mhz
    E6700=5680mhz
    QX9650= 6000mhz
    Xtreme Enthusiast TheWeaseL's Avatar
    Jul 2003
    0
    Ok, I'm gonna bite...Whats LDT/HT? Im guessing HT is hypertransport? But there is more then off and on?...
    The Voice of Reason Soulburner's Avatar
    Oct 2003
    Lincoln, NE
    0
    Correct, there is 1x, 2x, 3x and 4x the base clock speed.
    AMD spec is 4x or 800mhz HT. NF3 150 is only capable of 3x or 600mhz HT. 250 is supposed to fix this.
    250 will also have PCI locks....thats all i've heard.
    Windows 7 + SSD:
    Mode: AHCI, default Microsoft driver or latest Intel RST
    Defrag: Off
    Hibernation: Off (use Sleep mode, recommend a UPS)
    Indexing: On (it only indexes a few locations, not your whole system unless you tell it to)
    Page File: On (set to the minimum of 16MB if you have a large amount of RAM, disabling not recommended)
    Prefetch: On
    Superfetch: On (RAM is always faster than an SSD - use it)
    System Restore: Off (with regular backups)
    Browser Cache: RAM Only, Disk Cache Off (How to with Chrome)
    Documents, Music, Pictures, Videos, Downloads to HDD (Public Libraries too, see above link about junctions)
    UAC: On!
    Jun 2002
    Ontario, Canada
    2
    Amen to PCI/AGP locks! I just wish my K8V had an AGP lock. My 9600 Pro AIW doesn't like having an AGP speed over 70mhz. Sucks for overclocking...LOL
    As quoted by LowRun......"So, we are one week past AMD's worst case scenario for BD's availability but they don't feel like communicating about the delay, I suppose AMD must be removed from the reliable sources list for AMD's products launch dates"
+ Reply to Thread
