I am currently running the following WC setup in my NZXT Tempest:
Swiftech MRC220 Rad
2 x 140mm Noctua fans (Pull), 1 120mm Gentle Typhoon & 1 100mm Kaze (Push)
Swiftech Apogee GTZ CPU Block
XSPC X2O Delta Chipset Block
12V Laing DDC-1T (Pro or Ultra - cant remember) with XSPC Top
Swiftech MCRES Micro Revision 2
10/8mm compression fittings & tubing
I need to clean it again, but I am thinking of getting rid of it and going for a all in one kit that will have less chance of a leak and won't require me to clean it every 6-9 months or so (I don't OC my PC as much any more). I know an all in one kit won't be as good but will say the CoolIt ECO C240 A.L.C. (with my current fans) be able to cool my Q9550 @ 3.6ghz @ stock volts? I will just get a chipset HS and fan additionally.
Also would the CoolIt rad be able to fit in my Tempest (it is physically smaller that the Swiftech MRC220)?
