+ Reply to Thread
Results 1 to 5 of 5
Thread: !!Razer products and Goo-Off!!
    Xtreme Design NFC's Avatar
    Aug 2009
    Central Texas
    4
    This is a friendly warning to those of you who own Razer products.
    Goo-Off is a a great product which is safe to use on many plastics, but not the plastic Razer uses in its fine products.
    I own sever Razer mice, including the Lachesis, Death-Adder, and Mamba, as well as the Tarantula keyboard.
    Today I was removing the worn-out Teflon feet on my Lachesis and needed to get rid of the sticky residue left over. I should have tested the Goo-Off on a small area as per the instructions, but I had not seen the product adversely effect anything I had used it on and poured it on.
    The result is the plastic in Razer products actually melts and turns white like wax. Rubbing the Goo-Off resulted in leaving molded-smudged fingerprints on the bottom of the mouse, and making it not-level. I also managed to get two drips of the product on my Tarantula, which left ugly powdery white "acid burns" on contact.
    I tested a drop on the bottom of my Death-Adder and it left the same mark, and there is no way I am using it on my Mamba =P
    Be warned--when it comes time to replace your mice feet, use water and elbow grease. =D
    Not From Concentrate
    All Projects
    Previous Projects:
    S3 Mini ITX Chassis
    The ArK
    Uriel
    Israfel
    Veritas
    Eldritch
    Xtreme Cruncher HuffPCair's Avatar
    Sep 2008
    Kansas City, Missouri
    1
    Umm I never use goof off on plastic lol. Pretty sure its made to eat away most plastics.
    Should of just used rubbing alcohol
    ~ Little Slice of Heaven ~
    Lian Li PC-A05NB w/ Gentle Typhoons
    Core i7 860 @ 3gHz w/ Thor's Hammer
    eVGA P55 SLI
    8GB RAM
    Gigabyte 7970
    Corsair HX850
    OZC Vertex3 SSD 240GB
    Aug 2009
    Central Texas
    4
    I went with Everclear first, but it didn't do the job. Then I moved up to 90% rubbing alchohol, which still did nothing.
    All Projects
    Previous Projects:
    S3 Mini ITX Chassis
    The ArK
    Uriel
    Israfel
    Veritas
    Eldritch
    Devil kept pokin' slaveondope's Avatar
    Jan 2010
    South Kakalaky
    26
    NFC do you know if Razer provides replacement pads? Just got a Imperator and thats a concern of mine in the long run.
    Xtreme Enthusiast cabbspapp's Avatar
    Aug 2007
    Kent, Washington
    0
    Quote Originally Posted by slaveondope View Post
    http://www.performance-pcs.com/catal...ducts_id=27450
+ Reply to Thread
