So what shall i do? I am going to be going with a whole new build etc and was wondering should i just run all this in a single loop? or should i just run 2 seperate loops? If in just 1 single loop will this pump be able to push thru all the parts listed or should i split it into 2 loops? I will order more parts once i can begin my project.I am running low FPI rads with mid range fans (GT's) Also , i have been running compression fittings for such a long time but i change things so often to where its a PITA with the comp fittings now :/ .. I would like to try using BARBS and this will be my first time using barbs, what size would you guys recommend? and what tubing size should i go for as well.
Parts:
1x CPU WB-EK
1x Fullcover MB WB-EK
2x GPU WB's-EK
1x 175mm InH Res
1x EK DCP 4.0 Pump
2x 360 Rads
Example :
1 Loop- Res>Pump>CPU>Rad1>MB>GPU1>GPU2>Rad2>>Res
2 Loops-
1. Res > Pump > CPU > Rad 1
2. Res> Pump > MB > GPU1 > GPU2 > Rad 2
