hello,
i have the same motherboard listed in my sig. i had saved profiles of my overclocks. recently when i tried those profiles they fail. i'm positive they were good after running linx for almost 10 hours, on each.
i googled to find a similar problem. but the only thing i could find were references for the need to add voltage because capacitors get old, the article is from 2004.
i also tried different kits of memory from the same manufacturer thinking that would solve the issue. i currently use ballistix and changed the current set for a set of new ones i have laying around. changing memory did not help.
i'm thinking the power supply could also be another issue.
there's one more thing i thought strange. i've found my led fan, connected to the motherboard, would spin very slowly, as if almost getting ready to stop completely. could this be something with the power supply.
do i need to increase voltage to my components to make
my oc profiles work. just like they did when i originally
created them?
maybe there's a possibility of an easy fix. thank you for the help.
