In case you aren't aware of it, or in case it's just a regional problem of some kind, the ad in the upper-right corner of the page very often doesn't load these days. The result is that each page load / transition feels very slow.
EVGA SR-2 | Single X5650 6C/12T @ 2.67GHz | Noctua NH-U9DX push-pull | 6*4=24GB Kingston 1333 ECC RAM
Sapphire Toxic HD5850 2GB | Enermax Galaxy Evo 1250W | 2 * Dell 24-inch monitors
3 * LSI 9260-8i RAID + BBU | 2 * FastPath | 16 * Intel X25-M G2 80GB as two 2*(3+1) RAID-50 volumes
8 * Western Digital RE3 1TB as 2*(2+1) RAID-50 and 1+1 RAID-1 | Lian-Li PC-P80 case
4 * SuperMicro 2.5-inch 4-drive bays | 1 * SuperMicro 3.5-inch 5-drive bay | Pioneer BD-R
The result for me is that pages often don't render past the last post, meaning no Quick Reply
Xtreme SUPERCOMPUTER
Nov 1 - Nov 8 Join Now!
Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
It's gone here as well, but i don't have any problems with the site being slow etc.
--->TeamPURE<---
cant see add n page always trying to load
maximus IV extreme gtx580
gigabut p67-ud7
p67 sabertooth
2500k+2600k
antec 1200watt
EVGA classified 760
920 Batch# 3849B018 4.985ghz@1.52v gtx285 ftw sli
OCZ3RPR1866LV6GK hypers
dfi ut p35 rampage extreme
gigabut p35c-ds3r bios suks
gigabut x38-d6q dead thank god
ballistix 8500 1240mhz@2.02v
If you are using firefox, I suggest using adblock pro and noscript, they'll kill off 99% of ads, and XS is gonna load up lightning fast
Sig is under construction
Firefox once in a great while on a certain site may crash, or if i've kept it open for like a month straight Either way it's not bad, plus it reopens your tabs on restart
i3-8100 | GTX 970
Ryzen 5 1600 | RX 580
Assume nothing; Question everything
I don't think using things like AdBlock is a good idea, after all, sites relies on them to work.
Issue seems resolved today,at least for me..Using IE7
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
Yes, it's working now -- but this has happened a couple of times before. It breaks, then starts working, then breaks.... Not unlike some of my PCs.
