Hi guys,
I have some questions... hopefully some one can answer...
I was under the assumption that the LED on the back of this PSU was to display error codes/operation state.... but when I was looking through the manual I wasn't able to find anything referring to what the LED should be doing in certain states...nor could I find anything on the internet.
after turning the switch on.... the LED is red.... I was thinking it would be Amber for standby, and green when in operation?
the motherboard turns on when I hit the power button... but the light on the PSU continues to be Red...
I don't have everything plugged in yet.... All that is plugged in is the ATX and 8 pin mobo power (not sure what those are called).....could that have an effect?
I'm going to try plugging everything in see what that does... will post again once I do that.
.....basically to generalize the question.... Is this normal for the ST1000-NV?
Thanks for your time...
eKirts
