Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Changed from E6550 to QX6850 = Poor Overclock
    Jan 2008
    Flint, MI
    Hi everybody!
    I need help!!!!
    I had an E6550 on a Gigabyte P35C-DS3R, it was working like this:
    from 2.33Ghz to 3.5Ghz (7x500Mhz) - Stable at Linx Max memory 20 passes
    with my PC9200 memos at 1000Mhz(PC8000) 5-5-5-18
    I got an used, lapped QX6850 and now I can't even reach 3.5Ghz linx stable.
    The fastest config I can use is 8X425 = 3.4Ghz with 1.38750V on BIOS, 1,328V in CPU-Z
    Please can somebody help me?
    it's very annoying to overclock 4 times less (50% to 13%) a 10 times more expensive processor...
    Thanks!
    Sony Vaio VPCSA35GX while 7Mm away from home... Back at home:
    C2Q QX6850 3Ghz@3.4Ghz - P35C-DS3R
    XFX GT220 - 2x2Gb OCZ PC9200@1004 5-5-5-15
    3X500Gb + 64Gb - Case Thermaltake V-3 Black Edition
    AC F7 Pro + TR HR-05
    Xtreme Cruncher
    Jan 2007
    VA, USA
    Quote Originally Posted by Junimrox View Post
    Hi everybody!
    I need help!!!!
    Thanks!
    Updated your bios correct?
    It could be the fact that your 775 motherboard wasn't designed to take a Quad Core efficiently. I would check to see how many power phases it has.
    Click me
    May 2009
    Krypton, Hawaii
    Try a higher multiplier. 12 usually runs great.
    Jan 2008
    Flint, MI
    Kurz
    The bios is the newest, F12, and QX6850 is supported since F9, so i think that's ok... the mobo supports even QX9770 so i believe it should hold a qx6850...
    Kal-EL
    I thought I should try lowering the multiplier to get a higher fsb and more performance (assuming my mobo can hold a 500FSB as I used before), but now that you mentioned it I will make some tests with 12X...
    A screenshot for it running at 9X378:
    thanks all for the help, i'm doing some linx testing so it will take some time... but i'll answer in the mean time
    May 2009
    Krypton, Hawaii
    If you catch a good lead on your current overclock, the lower fsb should be offset by the final clock speed.
    Jan 2008
    Flint, MI
    tried to use 12X but no success, it didn't even boot, had to clear cmos every time, i tried 3 times... highest multiplier i can use is 11 and now i'm testing 318Mhz fsb = 3498mhz... Honestly i'm disapointed and kind of lost, i believe wither the mobo or proc is limmiting overclock, but I can't define which one is causing problems.
    May 2009
    Krypton, Hawaii
    What vc0re you at?
    Reference screeny with some cool h2o http://hwbot.org/community/submissio...ghz_9sec_420ms
    1.465vCore 400x11 =4400mhz
    Jan 2008
    Flint, MI
    I'm using 1.425 on bios but cpu-z reports 1.35
    I am Xtreme
    Sep 2006
    You noticed ya temps at only 3.4 ? 80°C , you got a hottie there...
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    Dave's Mentor!
    May 2007
    montreal
    on load it will drop even more around 1.28
    you need 1.5v in bios
    maximus IV extreme gtx580
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
    920 Batch# 3849B018 4.985ghz@1.52v gtx285 ftw sli
    OCZ3RPR1866LV6GK hypers
    dfi ut p35 rampage extreme
    gigabut p35c-ds3r bios suks
    gigabut x38-d6q dead thank god
    ballistix 8500 1240mhz@2.02v
    Jan 2008
    Flint, MI
    Yeah... I'm going to stick with 1.425V in bios, it's already getting too hot, 15-20 from TJ max.
    My ambient temperature is 25ºC, idle temp around 50ºC and full temp around 83ºC using a TJmax of 100 in realtemp.
    After all the afternoon testing I decided to go with 8x425 for now. I'll try to optmize some parameters but i gave up already.
    My main goal in changing processores was to have a great gain in performance and it happened, i went from 24Gflops to 44Gflops in Linx and the same video got it's conversion time lowered in 33%.(12 to 8 minutes)
    I'm sad that i can't overclock more because of extreme heat generated, but i'm not going to spend more money on this build unless something fails.
    Jan 2008
    Flint, MI
    Now i started lowering voltages, one by one I will test what I really need to keep it stable. since I can't have a higher frequency I will have low voltages...
    Dave's Mentor!
    May 2007
    montreal
    the biggest problem with that board is voltage instability
    better board wouldnt need so much voltage
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    Ahh yes Q & QX6000 series need some good mosfet board
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
    Jan 2008
    Flint, MI
    I noticed a very weird thing, now ehwn I first turn on the computer it immediately(2 seconds) turns off, and then when i try again it turns on as normal... could this be an issue with voltages not beign stable enough at start up?
    I am Xtreme
    Sep 2006
    euh when doing a cold boot isn't that normal behaviour for these intel boards ? wasn't it related to a strap setting
    Mar 2009
    +1 for a better board. A good P45 should leed you to a better OC and stability. + a good cooling !
    BTTB - Gigabyte Z87X-OC - WCed I7 4770k - 2x8gb Ballistix 1600mhz - Zotac GTX 780
    Asus Xonar Pheobus - OS -> Toshiba Q 256gb - Games -> 2x Agility 4 256gb Raid0
    Corsair HX850 - Tecnofront HWD BenchTable - Asus VE278Q 5760x1080
    Serveur - Asus Z77m PRO - 2500K - NH-C12P - 4x4gb G.Skill Ares 1600mhz
    Agility 4 128gb - Corsair CX430M - 1TB Black - 2TB green - 2TB Red
    KatPat - Gigabyte 990FXA-UD3 - FX-8320 - PH-TC14CS - 2x4gb Viper 1600mhz - GTS 450
    Samsung Evo 120gb - Corsair HX750 - Bitfenix Survivor White - Asus VE247H
  18. #18
    Jan 2008
    Flint, MI
    Quote Originally Posted by Leeghoofd View Post
    its normal?
    strap setting?
    never heard of it, should i know about it?
  19. #19
    Dec 2006
    Cochrane, Canada
    You might want to give ThrottleStop a try. Right click on it and select Unlock Max FID/VID and it should give you access and let you adjust your CPU multiplier from within Windows. It might help your overclocking efforts if you can boot up with a lower multi and then increase it when in Windows.
    ThrottleStop 2.84
    http://www.fileden.com/files/2008/3/...rottleStop.zip
    http://www.mediafire.com/?zdp17yqe71v2u97
    RealTemp 3.59.5
    http://www.mediafire.com/?vc6w5frn1gclpu9
  20. #20
    Jan 2008
    Flint, MI
    Quote Originally Posted by unclewebb View Post
    ThrottleStop 2.84
    RealTemp 3.59.5
    what an honor, unclewebb is in my post!
    Thanks dude, i'll give it a try, i quickly read the official thread of this software but thought it was only for dual cores.
    btw realtemp shows a 12 multipler when i set 11 in bios, I think there might be a bug, but it's only with 11 reporting 12, from 8 to 10 no problems...
    Last edited by Junimrox; 09-01-2010 at 12:49 PM. Reason: changed realtemp for coretemp
  21. #21
    Dec 2006
    Cochrane, Canada
    Some software gets screwed up when changing the multiplier and some bios versions are probably screwed up too. I bought a QX9650 earlier this year for testing purposes so hopefully both of the programs I posted above will show your multiplier correctly when in Windows. If you have any problems at idle, that's usually a sign that your C1E state needs to be adjusted or your Minimum processor state in the Control Panel - Power Options is not set to 100%.
    ThrottleStop is a handy multi-purpose tool and works very well with Core 2 and Core i, mobile and desktop CPUs and has a few features that no other free software currently has. I'm sure Intel has some good software hiding somewhere but they don't like to share the good stuff.
  22. #22
    Jan 2008
    Flint, MI
    i tested throttle stop and it doesn't allow me to raise the multiplier, i'm currently using 8 and the only available options are 6,7 and 8.
  23. #23
    Jan 2008
    Flint, MI
    Another thing everytime I turned the computer on it would quickly turn off and then turn on again normally, but I made it stop by changing the memory multiplier from 2.5 to 2.4... memory is slower but it was a PITA...
  24. #24
    Feb 2010
    Athlough I think it's time for a new motherboard, I also think that your CPU is just unlucky. You might have gotten one from a bad batch or something.
    My Media Center: Core 2 Quad Q9650 Yorkfield 3.0GHz, 2GB Kingston DDR2 800, Asus P5N7A-VM Motherboard with integrated Geforce 9300 OC'd, Samsung Spinpoint F3 1tb HD103SJ
    My OC rig: Asus P5PL2, Celeron D 356 ES @ 4.5GHz, 256mb*4 Micron and Samsung ddr2 @ 480MHz, WD400 40gb SATA, Asus EAX800XT Radeon x800 XT + Radeon 7000, Kingwin RVT-12025D heatsink
    Netburst FTW!!!....kinda.....
    Check out my tech blog @ http://spynoodlets.blogspot.com
  25. #25
    Xtreme Cruncher
    Jan 2007
    VA, USA
    Quote Originally Posted by spynoodle View Post
    Thats what I thought too.
    I bet its the motherboard not able to overclock a Quad core with the extra power requirements.
    Its only 3 phase I believe, In comprison a Rampage III uses 8 phase for CPU.
    Click me
