+ Reply to Thread
Results 1 to 4 of 4
Thread: GreenLee DMM w/temperature probe for ~$30
    Xtreme Christmas Lighter Jeff's Avatar
    Jun 2002
    Upstate NY, USA
    0
    http://www.lowes.com/lkn?action=prod...02-72068-DM-55
    Finally decided to upgrade my $10 pocket DMM from Radio Shack and ran across this GreenLee DM-55. Seems like a great deal for $30 and the temperature probe looks to be pretty accurate. I've tested it between 30f and 70f and it's been dead on so far.
    The overall construction seems decent and the included rubber guard is a nice touch.
    BTW, my RS DMM has lasted me 6 or 7 years and I have NOTHING bad to say about it. It's been through hell and back and it's still working fine(even been run over by my truck). If you want a really cheap DMM then I'd have no problems recommending it.
    [edit]AHHH CRAP! Radio Shack no longer carries the pocket DMM I am referring to. Seems the only one they have know costs $29.99.
    http://www.radioshack.com/product.as...%5Fid=22%2D820
    So the GreenLee DM-55 looks like an even better deal now.
    [/edit]
    Xtreme Mentor
    Nov 2002
    Delaware USA
    0
    Temp probe is a nice extra feature Lowes is 1 mile from my house, Might have to check i out tomorrow.
    I've got that same Radioshack tester but in a gray case. Older model.
    Dont even ask where i've been!!!
    Banned
    Jan 2004
    0
    can that temperature probe read below 0 degrees and also degrees C n F?
    Jun 2002
    Upstate NY, USA
    0
    I've had it down to -20f... and nope... it won't do C.
+ Reply to Thread
