Looks like one of my Dom GT's are bad. Considering booting hangs on post code 50 which the next in the series is 52 which relates to ram. Resetting bios and pulling all usb devices didn't fix the post 50.
Removing the chip in ram bank 3 allowed the computer to boot. Putting it back in causes it to hang on post 50 yet again.
I'm running memtest currently on chips in slot 1 and 2. Will later pull 2 and put it in 3 to see if its the slot or not. Then will put the one that was in 3 in slot 2 and run memtest if it will post.
My questions are:
Do you have to send the complete kit back?
Does Corsair actually repair your ram you send or do they just send new ram like Crucial does which usually is the newer crap they make. Which is why I wont deal with Crucial anymore. Lost my D9's to the junk they offer now.
What about the tall ram sinks? Will they return the new chip/s with them installed or will they take them off and give you the stock sinks? (I no longer have the stock sinks as I traded recently)
The matched set I have now are Cas 7. Isn't it true that the Cas 7 is still the better performing series of their GT's?
I'm quite sure if they just exchange I will get the newest run of chips as a replacement which if they don't perform the same its going to piss me off also just like Crucial did.
