Page 3 of 3 FirstFirst 123
Results 51 to 62 of 62
Thread: TessMark 0.2.2: New OpenGL 4 Tessellation Benchmark
  1. #51
    c[_]
    Nov 2002
    Alberta, Canada
    So it probably doesnt take advantage of the new method, oh well.
    All along the watchtower the watchmen watch the eternal return.
  2. #52
    Apr 2007
    New method? They increased the size of intermediate buffers and the benefit is at low to moderate levels of tessellation.
  3. #53
    c[_]
    Nov 2002
    Alberta, Canada
    Depending on the program. Heaven shows a bit of improvement but not a lot, MS's tesselation program fits ok.
    Here's the 16-pixel propaganda slide:
  4. #54
    Nov 2010
    Hi all !
    Is AI good ? While it seems to help some apps, others work well without. Any tips would be greatly appreaciated.
    EDIT
    These runs were done using full screen mode.
  5. #55
    Xtreme Guru
    Dec 2002
    windowed vs fullscreen: quite diff results - windowed = higher fps/scores
    no aa just pure insane tess @ 1080p
  6. #56
    Nov 2010
    I noticed that about windowed mode too , NapalmV5. And I'll bet your scores will jump 10-20% with a 64bit OS. No Physx ?
  7. #57
    Xtreme Guru
    Dec 2002
    physx @ cpu just the 2x 580
    was going to do a reinstall today either way so installing 64win7 in a few min.. but if all other 3d is any indication.. anyways ill have result ^ @ 64bit as well a bit later
  8. #58
    Feb 2008
    Quote Originally Posted by AmdAtiTom420 View Post
    Hmm, i actually see the exact opposite, higher fps fullscreen, lower in windowed, which is what i would expect as well. Though on insane it makes literally 4 points of a difference.
    cpu: AMD Phenom II 1090T
    motherboard: MSI 890FXA-GD70
    ram: A-DATA 4GB(2 x 2GB) DDR3 1333
    videocard: Sapphire Radeon HD6870
    powersupply: Silverstone DA1000 1000W
  9. #59
    Xtreme Guru
    Dec 2002
    those of you on single nvidia gpus run and post your results windowed just like the ati guys here
    anywho heres 64win7 - 5 points/1 avg fps diff
  10. #60
    Xtreme Guru
    Dec 2002
    64bit vs 32bit @ default normal settings
    64
    32
  11. #61
    Xtreme Guru
    Dec 2002
    tri-sli
  12. #62
    Nov 2010
    Quote Originally Posted by cirons View Post
    I'll run a few more to be sure. The results I've posted were done in full screen mode.
    "If I go insane , plz don't put your wires in my brain !" - Pink Floyd, If.
    Quote Originally Posted by NapalmV5 View Post
    OOops my bad heh.. The 10-20% I was thinking about, was the difference between Win7 64bit and Xp 64bit. Although, I have seen some performance gain going from 32 to 64 bit OS, but that was on 2 way less powerful systems.
    Peace
    EDIT
    I stand corrected for now. Fullscreen IS showing higher scores lol. But, I know I saw what I saw ! lmao
