View Poll Results: If Corsair made different cable lengths would you buy them? If so what size
Voters
46. You may not vote on this poll
  • Short size (HTPC)
    13 28.26%
  • Standard length (Stock)
    7 15.22%
  • Extra long for (Tower Cases)
    35 76.09%
Multiple Choice Poll.
Results 1 to 17 of 17
Thread: Corsair AX & HX Power Supply requests and suggestion
    Jun 2007
    Long Beach, CA
    I have a request for the new AX & HX series Power Supplies. Can you make different size cables? Maybe have three sizes to choose from? I am sure you seen many guys on here with there Custom sleeve jobs, and will sell out of them when you make them. You can add them on your Store etc..
    1. short size (HTPC) $19.99
    2. Standard length (stock) 24.99
    3. Extra long for (Tower cases)35.99
    CPU: Intel Core i7-4770K 4.8GHz
    MOBO: GIGABYTE GA-G1.Sniper M5 MATX 1150
    MEMORY: G.SKILL Trident X 8GB 2400MHz 9-11-11-31 1T
    GPU: 2 x eVGA GTX 780 SC
    SOUND KRK Rokit 5 Limited Edition White Studio Monitors
    SSD: 4 x Samsung 128GB Pro's Raid 0
    PSU: SeaSonic Platinum 1000W
    COOLING: 2 x Alphacool NexXxoS UT60 Full Copper 420mm 6 x Swiftech Helix 140mm Fans
    CASE: Lian Li PC-C32B TECH STATION MOD build log coming soon
    MONITOR: ASUS VG278HE Black 27" 149Hz
    O.S: Windows 7 Pro x64
    Nov 2009
    Bloomfield Evergreen
    It's pretty nasty to do cable management with HX1000 inside tower cases, especially the 8-pin and 24-pin cables.
    Dec 2008
    Australia
    Yes I would buy the extra long cables
    Corsair Rep
    Apr 2004
    I'll pass this on to the PSU product manager.
    Yes, Yellowbeard, a tall rough man with a big yellow beard
    Jun 2007
    Long Beach, CA
    Quote Originally Posted by Yellowbeard View Post
    are you guys planning making extra cables? As of right now I been buying only SilverStone series fully modular because they have the different size cables. Not trying to tell you how to run your business but I am positive if you make them they will sell out.
    Corsair Rep
    Apr 2004
    I can't comment on unreleased or unannounced products but, if I get any information that I can share I will post it here. I have asked the PM for clarification.
    Corsair Rep
    Apr 2004
    From your poll:
    You may want to add an option for
    No, I would not buy them.
    Also, I have no reply from the PSU PM at this time.
    Xtreme Mentor
    Jan 2009
    Oslo - Norway
    AX 1200w should have a few long cable, because that's a good PSU for EVGA SR-2, and that MB is HUGE.
    SR-2 needs a 10-slots case actually, so if you are mounting the PSU at the bottom you would need a few really long cables, specially a couple for 8-pins CPU, and couple of optional 6-pins that would need a long cable too.
    I've actually a AX 1200W on order (it is delayed again EAT next week ) for my SR-2 build, and have been hoping that cables will be long enough when i move it to a new proper case.
    ASUS P8P67 Deluxe (BIOS 1305)
    2600K @4.5GHz 1.27v , 1 hour Prime
    Silver Arrow , push/pull
    2x2GB Crucial 1066MHz CL7 ECC @1600MHz CL9 1.51v
    GTX560 GB OC @910/2400 0.987v
    Crucial C300 v006 64GB OS-disk + F3 1TB + 400MB RAMDisk
    CM Storm Scout + Corsair HX 1000W
    EVGA SR-2 , A50
    2 x Xeon X5650 @3.86GHz(203x19) 1.20v
    Megahalem + Silver Arrow , push/pull
    3x2GB Corsair XMS3 1600 CL7 + 3x4GB G.SKILL Trident 1600 CL7 = 18GB @1624 7-8-7-20 1.65v
    XFX GTX 295 @650/1200/1402
    Crucial C300 v006 64GB OS-disk + F3 1TB + 2GB RAMDisk
    SilverStone Fortress FT01 + Corsair AX 1200W
    Xtreme Cruncher
    Oct 2007
    Yeah, i'd get some of the extra long cables (MM extended ascension case.) I own a HX1000 now and will be upgrading to an AX1200.
    XTREMESupercomputer: Phase 2
    Live up to your name - November 1 - 8
    World Champion - IRONMODS
    Sep 2007
    Northern Japan
    Extra long I could see....but anyone wanting to do a nice custom job will cut cables to specific lengths anyway IMHO
    Quote Originally Posted by Massman
    My definition of 'efficient' is 'it does not suck monkeyballs'. Yes, I set bars low.
    [CENTER]The post counter is not an intelligence meter!
    MAX11L - "It's like a console...with the suck turned down and the awesome turned up" -tet5uo
    Heat Team IRONMODS
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Yeah custom cables would be nice, i know both enermax and silverstone are offering this if asked nicely on per customer basis. Enermax doing it free of charge heh
    Administrator andressergio's Avatar
    Jul 2007
    Montevideo - Uruguay
    agree also would be nice to include at least 1 with sata connectors arranged in a way for ppl puting the PSU on the bottom as in my case i have to twist them to make them fit my 4 HD
    Intel Core i9-7980XE@ 4.8GHz 18C/18TH (Direct Die Contact)
    ASRock X299 OC Formula
    ADATA XPG SPECTRIX D80 (4x8GB) DDR4-3800C17 B-Die
    1x Intel Optane SSD 905P 480GB
    4x HP EX950 NVMe 2TB on ASRock ULTRA M.2 CARD
    EVGA RTX 2080TI KINGPIN 2190/8000 Stock Cooling AIO 240
    SilverStone ST1500W-TI TITANIUM
    Alphacool Custom Water Cooling
    Oct 2010
    +1 for longer cables
    Aug 2010
    +1 Here too....
    Gaming = Q9400|H50|GTX470|9800GT|EP45-Extreme|4GB 1066|650W|800D|3-X233H|Logitech illuminated|Mamba|
    Game Server = PE2650|Xeon 2.4GHz|512MB Ram|5X36GB SCSI|
    File Server = E6500|2GB|2.5TB|GT210|
    FREE WEB HOSTING!
    How to Flash GTX465 To A GTX470!
    L-l-look at you, hacker.
    Jun 2007
    Perth, Western Australia
    I had to engage in an epic battle with the 8-pin EPS connectors on my HX-1000 to get them to run behind the mobo rather than across the middle of the case. They put up a hell of a fight, but I got them to go eventually. Would have definitely appreciated an option for longer cables, especially for the 24-pin and 8-pin connectors - in a PSU where everything else is modular excess length on these is really not that much of a problem for those with small cases.
    Rig specs
    CPU: i7 5960X Mobo: Asus X99 Deluxe RAM: 4x4GB G.Skill DDR4-2400 CAS-15 VGA: 2x eVGA GTX680 Superclock PSU: Corsair AX1200
    Foundational Falsehoods of Creationism
    Mar 2008
    Alberta Canada
    Longer cables/tighter spaced SATA power connectors would be nice also (single spaced/double spaced rather than nearly triple spaced)
    Current System:
    eVGA 680i SLi "A2" P30 BIOS
    intel Core 2 Quad Q6600 (currently at stock)
    OCZ ReaperX 4GB DDR2 1000 (running at DDR2 800 Speeds with cas4)
    320GB Seagate 7200.10
    XFX 8800GT XXX 512MB (stock clocks)
    auzentech X-Fi Prelude
    PC Power and Cooling Silencer 750 Quad Copper
    Win XP Pro
