Hi, I was wondering if anyone knows wether, for the same flow rate, using an undervolted [or HF PWM] duel ddc is quieter than using a single pump run full bast?
chears for you help.
I did estimate this yesterday,
1 laing 18w - 1.18 gpm
2 laings 18w - 1.68gpm
2 laings 9w - 1.4gpm
so 2 laing 3900rpm have more flowrate than 1 laing 4500rpm
next, pumps are rated at 8v minimal which is 70% of 12v, so undervolted 10w laing will run at near 2700rpm, i guess it'll be very quiet
Intel Xeon W3520 4200MHz HT
Foxconn Bloodrage
3x2Gb Patriot Viper II DDR3-1600 6-6-6-16
MSI GTX480 M2D15 850/1700/2000
Samsung F1 1TB
Corsair TX950W
Stacker 832 w/ Dual Loop Watercooling aka *Bong Build*
NEC 2690WUXi
Loop 1: Laing DDC1-T -> Watercool HK 3.0 LT -> Thermochill PA120.3 -> Bloodrage NB -> EK Res 150
Loop 2: Laing DDC1-T -> EK-FC GTX480 -> Thermochill PA120.2 -> EK Res 150
*New* CM 690 II Advanced Watercooled
*Coming soon* Stacker 832 Rebirth!
Cool. Thanks for the info!
Core i7 920 @4.31ghz (HK3.0+MCR320Drive) [DT Air/CPU @ 13c idle, 45c IBT]
MSI GTX 295 Single PCB with EK 295 + MCR320 Drive + 1450rpmGT [DT Air/CPU @ 10c idle]
Asus R3E . Corsair TX850 . OCZ 12Gb 1333mhz RAM
