I'd spend the 30.00 on the R-1000 its worth the money.
use distilled water not tap.
Good luck to your project.
i7 6700K @4.8 ghz
XSPC RayStorm (very nice block)
Z170 Sabertooh ,, 32GB- Gskill (15-15-15-36 @3600 mhz) 1:1
XFX-7970 with Swiftech Komodo nickel block
Water Cooling - MO-RA3 Pro with 4 Silverstone 180mm @ 700 rpm, Twin Vario mcp-655 pumps
Samsung 850-1TB SSD,, OCZ ZX-1250W (powerfull and silent)
Crossfire 30" decent monitor for IPS too bad SED tech died
Docsis2.0 Docsis3.0
-- People who reject the idea that "government has a responsibility to reduce income inequality" give an average of four times more than people who accept that proposition.
by any chance do u know if i can find R-1000
locally
water_cooler,
Your beating your head against the wall .
Just use the Denatured alcohol with "NO WATER" and the clearflex.
Get a decent reservoir that doesn't have a hole in the bottom of it. (I'll sell you mine if that will help)
Put a top on it and seal it up with armaflex (you can get armafex at home depot, along with the denature alcohol) The armaflex is in the air condition department and the denatured alcohol is in the paint section.
Now go to Home Depot.
this may sound kind of noobish but what is armaflex
We are all noob, no prob with that.
Armaflex is an insulation tape It's 1/8" thick and 2" wide. It comes in a roll.
You can wrap your clearflex with it. Seal the lid on the reservoir with it. I covered the styro-foam lid with strips of armaflex.
It's just a tape that will seal and insulate.
I have a roll of this stuff
will it work
Imagination is a powerful tool.
Rubatex is the same stuff. Just a different brand.
that looks like what i have
i just got back from home depot and I got the Denatured alcohol
and a lexan top for my res
now i used my tape to seal the res here is a pic
also i think i will use the return line to fill the sys
if you have any problems with the lexan for a top due to the methanol attacking it use glass for the next top. If you don't run into a cracking problem don't worry about it.
Gasoline attacks lexan and makes it brittle not 100% sure about methanol just giving you a heads up just in case.
i7 6700K @4.8 ghz
Docsis2.0 Docsis3.0
ok so i guess i shouldn't fill it to the top then
also should i go 50/50 w/ methanol and water
or just go 100% methanol
your personal preff
and how cold it will be
i7 6700K @4.8 ghz
Docsis2.0 Docsis3.0
i think it will be around -30C to -40C
somewere around there
Isn't clearflex rated to only like -25? Also like previously posted you don't need a 100% methanol solution.
Man , I just saw that pic, Well,we tried,
I'm,
speechless...
good luck.
Water_Cooler,
i thinik i'm going to make a few adjustments to my cooler
1st I'm going to try to make a coxial heater exchanger for my colant to be cooled off
2nd I got a nice R22 3/4HP 9000btu compressor that i'm going to use to replace my old R12 1/6 HP com
here is a pic
hey how large is that ??
also how loud is it?? when you get it going
oh is this the same unit ?? ---> http://www.panasonic.com/industrial/...s3r126a-6a.pdf
thanks
i7 6700K @4.8 ghz
Docsis2.0 Docsis3.0
the compressor is 10 1/2 in tall
I don't know how loud it yet
I don't think the one in the link is mine because in the link it is talking about a 6000btu compressor while mine is 9000btu
but i think its the same type as mine just a differnt btu
I will try to get it going as soon as possible
i'm thinking about making the heat exchanger 10ft would this be too much
Update i got an even better compressor now i got one from a friend its a 9100btu compressor 100btu more than my other compressor should i use this one instead of the one in my last post
pic:
i already have a vaccum pump
the compressor i'm going to use in the above pic has a 1/2 suction line if i use 1/2 tubing for the suction line will that degrade the cooling power of my evap since my evap is made from 3/8 tubing which is smaller than 1/2 tubing
No, it will not degrade the cooling power. However, it will reduce the velocity of the vapor, which makes it less able to transport the oil back to the compressor. If the suction line is downhill to the compressor then it doesn't matter, because gravity will move the oil, but if it is uphill you need that velocity.
so i just need to make the suction line go down hill to the compressor and i won't have any oil issues
