Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 114
Thread: Chilled water (56K beware)
  1. #51
    Dec 2002
    USA, FL
    would the WWF do a better job then the antifreeze because the
    antifreeze mixed with water frozed up
    would a 30%water 70%antifreeze work for me or would that get to thick
    acorrding to dabit's charts at that mix u can go down to -42C
  2. #52
    Banned
    Dec 2003
    Not here
    It was the water in the antifreeze that froze. Get rid of it....forget the idea of putting water in it @ all. Try the antifreeze mixed with the methynol or the WWF. You dont want it to get slushy, and even if it can go down to -42c, that doesnt mean its not gonna be slushy.
  3. #53
    Dec 2002
    USA, FL
    does anyone know how much 3M's Fluorinert liquid FC-72 cost
    and were i could find it
    if i could get a hold of it would probably help since it freezes at
    -90C
    here is info about it
    http://products3.3m.com/catalog/us/e...lmaterials_3_0
    or would i be better off using a 50/50 antifreeze and WWF mix
  4. #54
    Nov 2003
    Olympia, WA
    Food grade orange oil
    http://www.floridachemical.com
    Imagination is a powerful tool.
  5. #55
    Oct 2003
    USA /okla
    -90C
    FC-77 which cost 375.00/gal. 13 yrs ago when I was going to submerge my amps for car audio I compete in nationally now costs 378.00/gal. Either the prices haven't changed or my memory isn't that good. Either way its nearly 400.00 per gallon.
    Its the best but costly.
    i7 6700K @4.8 ghz
    XSPC RayStorm (very nice block)
    Z170 Sabertooh ,, 32GB- Gskill (15-15-15-36 @3600 mhz) 1:1
    XFX-7970 with Swiftech Komodo nickel block
    Water Cooling - MO-RA3 Pro with 4 Silverstone 180mm @ 700 rpm, Twin Vario mcp-655 pumps
    Samsung 850-1TB SSD,, OCZ ZX-1250W (powerfull and silent)
    Crossfire 30" decent monitor for IPS too bad SED tech died
    Docsis2.0 Docsis3.0
    -- People who reject the idea that "government has a responsibility to reduce income inequality" give an average of four times more than people who accept that proposition.
  6. #56
    Dec 2002
    USA, FL
    wow thats alot of $$$$$$ i guess i'm going to try out
    a mix of antifreeze and WWF
    or should i try WWF and water 1st just to see if that gets the job done
  7. #57
    X.I.P.
    Jul 2003
    Darby FL, USA
    Forget the water. Use WWF. If it slushes, pour in a can of gas line anti-freeze. Keep adding gas line anti-freeze each time it slushes.
    Author - Refrigeration Trouble Shooting Books
    Want to learn more? Click Here
  8. #58
    Dec 2002
    USA, FL
    so u mean just use stright WWF
    also is WWF dangerous in any way
  9. #59
    X.I.P.
    Jul 2003
    Darby FL, USA
    Yes. Use straight WWF.
    It is not healthy to breathe it. And you don't want it to evaporate either. For both reasons, keep it covered.
  10. #60
    Dec 2002
    USA, FL
    Does WWF small bad and would i need an airtight res to use it
  11. #61
    X.I.P.
    Jul 2003
    Darby FL, USA
    Yes. And yes.
  12. #62
    Dec 2002
    USA, FL
    also wouldn't it be better just to run stright methanol instead of the WWF or will ether way get the job done
    also would stright methanol or WWF low viscosity cause my pump to have any problems since there viscosity is lower than water
  13. #63
    X.I.P.
    Jul 2003
    Darby FL, USA
    Your system isn't going to get cold enough to need straight methanol. The WWF, along with a can or two of gas line anti-freeze should do the job.
  14. #64
    Oct 2003
    USA /okla
    WWF has water in it. I think its a 70/30 mix for -20F solution.
    here is a quote from another thread
    from iboomalot
    and WIPER BLUE uses methanol a form of alcohol
    see for yourself::
    quote:
    II. HAZARDOUS INGREDIENTS
    MATERIAL OR COMPONENT CAS# % OSHA PEL TLV HAZARD DATA
    Deionized Water 7732-18-5 67.00
    Methanol 67-56-1 33.00
    Pyaklor S-405 Blue N/A
    HMIS:Health-1, Flammability-3, Reactivity-0, Personal Protection-B
    entire link can be seen here
    http://www.douglasproducts.com/commercial/msds_ww.html
    "WWF low viscosity cause my pump to have any problems "
    No its lower than water but thats a good thing for better flow and cooling properties. Its not too much lower to endanger your pumps.
    i7 6700K @4.8 ghz
    Docsis2.0 Docsis3.0
  15. #65
    Dec 2002
    USA, FL
    should i use copper tubing instead of plastic water tubing for my water cooling sys this way i don't have to deal with brittle tubing at cold temps
    like in this article
    http://wc101.com/articles/coppertubing.php
  16. #66
    Oct 2003
    USA /okla
    tygon R-1000 would be killer its good to very low temps and its very flexible.
    i7 6700K @4.8 ghz
    Docsis2.0 Docsis3.0
  17. #67
    Dec 2002
    USA, FL
    is it expensive
  18. #68
    I am Xtreme
    Aug 2003
    Cherry Hill, NJ
    My res isint 100% air tight. Is the WWF in there killing me?
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
  19. #69
    Oct 2003
    USA /okla
    TYGON® R-1000 Ultra Soft Tubing
    Ultra-soft and flexible
    Performs well at low temperatures (to -100°F)
    Excellent for use in low-torque pump applications
    Tygon® R-1000
    Tygon® Ultra-Soft Tubing resists a broad range of aqueous chemicals and provides an excellent alternative to silicone tubing in applications where corrosive chemicals are used. Its minimal resistance to compression permits use in low-torque pump applications including battery driven types.
    Tygon® Ultra-Soft Tubing stays flexible at temperatures as low as -100°F (-73°C ). Its smooth bore facilitates easy cleaning and helps prevent possible buildup. Do not autoclave. Durometer hardness: Shore A, 40.
    prices vary I think its 2 - 4.00 per foot
    i7 6700K @4.8 ghz
    Docsis2.0 Docsis3.0
  20. #70
    Banned
    Nov 2003
    portland oregon
    Ok correct me if I'm wrong,But isn't WWf just 20 to 40 percent methanol (based on what brand temp rating ect.) the other ingrediants being water and a bit of detergent? if so wouldn't it be less money and hassle to just purchase the methanol add in your own water and omit the detergent you don't need ? Also giving more control over the amount of water and removing some of the guesswork.
  21. #71
    Dec 2002
    USA, FL
    u might want to seal it from what i have read WWF has about 33% methanol which isn't good to brethe
    so were would i go about getting R1000
  22. #72
    Oct 2003
    USA /okla
    http://www.integraco.com/r1000p.htm
    50' roll is like 120.00 I can find a place that stocks smaller lengths or do an ebay search maybe.
    hunt around on the web some places want 6.00 a foot just look around you can find the 2-4.00 a foot prices
    i7 6700K @4.8 ghz
    Docsis2.0 Docsis3.0
  23. #73
    Dec 2002
    USA, FL
    i found this place that has a 10fyt pack for $30
    http://www.aptinstruments.com/Mercha...Code=Vinyl_TBG
    but i think it might be cheaper to use copper tubing
  24. #74
    Banned
    Nov 2003
    portland oregon
    copper for your coolant would be a :banana::banana::banana::banana::banana:, limiting your mobility. R-1000 good choice, I'm using R-3603.
  25. #75
    Dec 2002
    USA, FL
    maybe i should just save the time and money and just use my clearflex60 that i have
    i'm also think i will probably go with methanol and water mix unless someone can give me a better idea
