Hi all,
I have a Western Digital SATA 6Gb/sec 1TB Caviar Black (WD1002FAEX).
It's plugged into one of the SATA III ports on my motherboard(SATA1), but I can't seem to find anywhere to check whether it's actually running SATA III of SATA II.
AMD overdrive says SATA II when I view the drive properties, but I think it may be incorrect.
Is there a program I can use to check which SATA it is running?
Thanks for any help
System specs
MSI 890FXA-GD70 Bios 1.6
AMD Phenom II X6 1055T
4GB Samsung 1333MHz el cheapo RAM
MSI 8800GT OC 512Mb
Corsair TX650W
WD 1TB SATA3 Black 7200rpm
Seagate 1TB SATA II 7200rpm
Corsair H50
CM Storm case
