+ Reply to Thread
Results 1 to 17 of 17
Thread: Recommend a pump with a 3 pin connector
    Dec 2009
    0
    Hi guys
    I want to replace the pump in my machine (http://www.silentpcreview.com/forums...ic.php?t=56550). The case I'm using, uses a pump with a 3 pin connector. Can you guys recommend a good water pump that does have a 3 pin connector?
    Thank you
    Xtreme Member jumper2high's Avatar
    Dec 2004
    Novi Sad, Serbia
    0
    Both MCP355 and CPX-Pro (sold under many names, by a few companies) are the best pumps you can get, and they both come with 3 pin connectors.
    Dec 2009
    0
    Thanks for the advice jumper2high. When I get home (office firewall impedes me to check on these pumps) I'll check them up.
    Xtreme Guru Church's Avatar
    Dec 2009
    Latvia, Riga
    5
    didn't MCP355 (or Laing DDC 3.2(5)) have 4 pin connector for power and single wire 3pin for rpm tach wire? IIRC only it's variant by Koolance (PMP-400) had both of these wires united in 3pin connector. Not that hard to mod that though with any pump.
    Dec 2009
    0
    OMG churchy I was just checking http://www.koolance.com/water-coolin...product_id=334.. and thought to post it here.. but it seems you beat me
    Anyway I like the Koolance PMP-400 and its heat sink http://www.koolance.com/water-coolin...roduct_id=1058
    I'm wondering if Koolance ships to Europe. I'm from Spain.
    Xtreme Enthusiast TJ TRICHEESE's Avatar
    May 2009
    0
    koolance ships to most places including the UK
    Dual E5530's @ 3.7ghz Watercooled
    Evga SR-2
    GTX 480 TRI-SLI Waterchilled
    24Gb samsung 30nm HYK0
    Coolermaster 1200w PSU
    Quote Originally Posted by Some guy on a xbox forum
    a colder environment round the Xbox itself won't really cool it down because the xbox doesn't take in air, it just expels the hot air I think.
    Dec 2009
    Latvia, Riga
    5
    and most of LC shops usually have at least some of koolance products
    Xtreme Enthusiast justin.kerr's Avatar
    Mar 2009
    0
    it is very easy to put a 3 pin connector on any 12V or 5V PC low amperage component.
    Email/web browsing PC
    MM Ascension case, 24/7 settings
    Classified, 980x @ 4,525Mhz, HT on 1.39V
    (3) ATI 5870's@ 1062Mhz
    G skill perfect storm RAM s 6gb, 2,176 Mhz CAS 8
    (4) intel x25m RAID 0
    CPU loop, EK supreme HF, EK mobo block, 500MM bitspower res, 2 DDC 3.25's on XSPC top, 2 XSPC RX 360's, 1 XSPC RX 480, GPU loop, EK water blocks, with nickel backs, 2 swiftech mcr 320's, 500MM bitspower res, ddc 3.25, XSPC top all with 1850 RPM gentle typhoons
    plus many other rigs.
    Apr 2010
    Palo Alto, CA
    0
    Does the aquastream xt use a 3pin?
    I am Xtreme Waterlogged's Avatar
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    0
    I normally convert all my DDC to 3 pin for neater wiring.
    Quote Originally Posted by bobisgod View Post
    Nope, it has a 4 pim male connector on the back.
    http://www.xtremesystems.org/forums/...d.php?t=216329
    Circles SucQ!
    OVERCLOCKAHOLICS OC Maximus's Avatar
    Jul 2010
    Hawaii
    35
    Let me get this strait. My MCR355 has a 4 pin for power and a 3 pin to plug into the MB for rpm signal. You guys are saying that I'm able to mod the wiring so that it uses a 3 pin connector only? I guessing after modding the wiring you can no longer plug it into the MB, it would have to come directly off the PSU and you would loose the ability to read RPM?
    Thanks,
    Jun 2007
    0
    Quote Originally Posted by OC Maximus View Post
    Thanks,
    My preference in PSU's (Antec NeoHE) allows me to make a lot of my own cables. What I do is convert the pump to a 3 pin connector then make a cable that has a 3 pin on the end of it. The RPM sense wire still goes to the MoBo or a fan controller, it just takes a slightly less direct route.
    Circles SucQ!
    Jul 2010
    Hawaii
    35
    Ah, got it. So you'll end up with (2) 3 pins instead of a 3 pin and a 4 pin. On to the MB and the other to the PSU. Makes sense now, sure would be cleaner in my case. I'll keep that in mind when I get ready to sleeve.
    Dec 2009
    Latvia, Riga
    5
    If you use some advanced pump/fan controller for pumps (eg. aquaero/TMS-200/BigNG), then imho it makes sense for single 3 pin connector, so that both rpm signals go to controller and pump's voltage is regulated from it all by same connector/wires. As for which color wire is for what or which pins in connectors (4 pin or 3 pin) provides what voltage or are used for rpm tach, can be easily googled out.
    Jun 2007
    0
    Nope, cleaner than that.
    Circles SucQ!
    Xtreme Addict MpG's Avatar
    Jul 2007
    Canada
    0
    If you're not a fan of modding, the CPX-Pro and DB-1 pumps are both good options. And I suspect even the little DB-1 will kick the butt of whatever Zalman offered in that case originally.
    i7 2600K | ASUS Maximus IV GENE-Z | GTX Titan | Corsair DDR3-2133
    Dec 2009
    0
    Thank you very much for all the information provided. I think, thought at the moment I'm not sure, that I'll go with the Koolance PMP-400 and its heat sink. I like the concept. I'll also probably buy some other things all from Koolance, like quick release couplings, barbs, etc.
    Regarding the Zalman case is not that bad.
    Right now my CPU stays idle at 42ºC and primes at 65ºC. Room temperature is about 30ºC right now, here in Madrid. The CPU is i7 920 at 2.8 GHZ.
    Weird thing, is that 2 days ago I've changed my TIM for the CPU from AS5 to AC MX3. With AS5 my CPU used to prime95 at 60ºC, at 30ºC room temperature. Right now with MX3 it primes at 65ºC.. Better idle temps, but worse load temp. I've ordered some Gelid GC Extreme. I do hope it's better than MX3 at transferring heat.
    I know the Zalman thing is not for hardcore over-clockers, but it serves me well in my needs of getting slightly lower temps that air cooling and also lower noise. The case when setted on automatic, is pretty quiet.
+ Reply to Thread
