Need Help With Samsung p800 HDDERASE FAILED(AKA-- Corsair p256)
Hey all,
I have an Samsung SSD P800 256 GB same drive as Corsair p256.
I have had my OS win-7 64bit Running smothly since October, seemed to be a little slower since fresh install,
so i decided to do an HDDERASE 3.3 like i did many times before and reimage the SSD.
This time the HDDERASE failed to do a secure erase and now my system will not detect the drive!!!!
What progys or bios steps can i do to see and reformate this drive/ or is it toast?
BTW i have had this SSD for 2 years no problems, and it is running the latest firmware.
Thanks,
ASUS Rampage II Extreme | i7 920 cpu | Corsair Tri Channel 6 GB | GTX 580 FTW Hydro | Corsair P256 SSD| 4 TB OF HDD | Corsair HX1000 PSU
Loop #1: TFC 480 | KOOLANCE 350 BLOCK | Loop #2: TFC 360 | FTW HYDRO | Swiftech NB Block | MM Pinnacle 24 Case
HEAT
Current on going build, Mountain Mods Pinnacle 24
- You may not post replies
- You may not edit your posts
Forum Rules
