Hello everyone
At first excuse me for my bad english as I don't speak this language fluently.
So I have this kind of problem. As I try to change voltage of the cards GPU using Afterburner (ver 1.5.0, 1.5.1, 1.6.1) there is no change at all. Both voltage control and monitoring options enabled. In 2D card maintains 0.973V (Afterburner shows 0.949V), when I enter 3D mode (Kombustor, Heaven 2.0, 2.1 benchmark)- the GPU maintains 1.175V although Afterburner shows my desired voltage. Also in 3D when multimeter shows stable 1.175V, in AB spikes appears like 0.600V or 0.949V. And more interesting when I check option "force const voltage" the graphics driver hangs (red or blue pattern all over the screen) and OS hangs also. I've used 10.6 and 10.4 Xtreme-G drivers so far. I also tried flashing BIOS. So i tried this solution
http://hwbot.org/forum/showpost.php?...4&postcount=10
and this one also
http://www.techpowerup.com/vgabios/7...24.100305.html
with no luck at all.
Guys please help...
My system:
Motherboard: Asus Rampage Formula (Mr. Solors mod bios 0001);
CPU: Intel Q9450;
RAM: G.Skill 2x2 DDR2-1200 CL5;
PSU: Enermax Infinity 720W;
second GPU GeForce 8800GTS G92. I tried settings w/ and without Geforce.
All settings using system on stock, no OC.
