Well if you guys can't cool it then you probably shouldn't buy it.
why are tantalum caps not used on this one?
Gigabyte GA-X38-DQ6
Core 2 Quad Q9450 @ 3.4Ghz (Zalman CNPS9700 LED)
Corsair Twin2X4096-6400C4DHX @ DDR2-1066
RIP GeForce 9800 GX2 715/1720/1050
2 x 500GB WD Caviar SE (RAID 0)
Corsair HX-620W
ACER P243WAID 1920 x 1200
1. how? custom bin from nvidia? i doubt it...
how do you pretest a massive bga chip like this please?
way way way too complicated and time consuming = expensive
2. awesome pcb design... better than that of highend non ref 480s? dont think so... and even if, you are only going to notice it on ln2...
3. so these are going to be dual slot only? i find that very hard to believe... and even if... quad 480 sli... with a dedicated physix card... right... why dont you just bolt 2 more 480s to the side of the case? that probably improves your gaming experience even more... its hard to measure, but its true! you can feel it, give it a try! ^^
I like your style of comedy.
ASUS recieves chips. ASUS tests chips. Good chips go in non reference 480's. Really good chips go in MARS 2.
As for awesome PCB design I was meaning fitting that many MOSFET's and power phases along with memory and two GPUs on a single PCB that is THAT small.
Smile
I'd buy 2 of these rather then 4 GTX480 just so I'd have room left over for a raid card, sound card, etc.
:P
how???
you either need a custom bin machine which would cost 100k us if not a LOT more than that, or youd need custom 480 pcbs with a pressure bga strap on socket. ive seen those sockets for memory chips, but thats sub 100pin and thats already buggy, getting good contact with those sockets is a huge pita... especially if you actually have to cool the chip actively somehow...
its not impossible, but i find it very hard to believe that anybody does this right now... nvidia probably has a custom bin machine, but i HIGHLY doubt any of their partners have one, or that nvidia gives them access to them or gives them custom bins...
its not impossible, but unlikely...
very unlikely...
sorry, without any infos about how asus supposedly does this, i call
the only time i can imagine something really gets binned if there are 2 versions of one product that use the same pcb... then yeah, sure, its easy and viable to bin... otherwise its just not viable...
A thousand dollars would be a bargain considering two of these cards already cost that much.
Considering this is an absolutely unique product(not a existing product with pumped up ram), this is going to be very expensive for Asus to make.
The cooler on this chip is going to have to be the mother of all air coolers if it makes it to production. Honestly they should sell it for 1400 MSRP and put a good water block and a premade water cooling solution ALA corsair h50.
Core i7 920@ 4.66ghz(H2O)
6gb OCZ platinum
4870x2 + 4890 in Trifire
2*640 WD Blacks
750GB Seagate.
racing games should feel great with that wind in your hair from those two outside mounted 480's
Mars II - well somehow I hope we can set one under ln2 on GC 2010 like we did with Mars I back in 2009 but apart from that I would never consider buying it myself...I would go for some solar cells first
And for the question "What was first - chicken or egg?":
| '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
| '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
| '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
| '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
| '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
| '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
| '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
| '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
Originally Posted by saaya
