+ Reply to Thread
Results 1 to 10 of 10
Thread: Oil Sep : AB oil freezing temp
    Xtreme Mentor sdumper's Avatar
    Aug 2006
    Atlanta
    8
    Specs:
    Lowest zero load temp: maybe -85c/-88c but not for long and that temp will be in a 10 plate HX flowing fast
    Running idle temp -76c or so
    Load temp -68c to -74c
    Metering TXV 01 orifice
    Gas Ethane r170
    Can I get by skipping the oil sep under the scenario above?
    I really dont want to spend $154 on a floated Temprite 900 series oil sep and i dont want to use a cheap manual one...
    Never empower an idiot with a response....
    http://en.wikipedia.org/wiki/Troll_%28Internet%29
    Seller/Buyer Reputation:
    Heatware: http://www.heatware.com/eval.php?id=50905
    Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
    Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
    iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
    Xtreme Addict Jack's Avatar
    Jul 2004
    The Netherlands
    0
    Does the AB oil spec. sheet mention a freezing temp?
    But I'm guessing that at -76* C idle, you would be cutting it close...
    Why not use a simple home-build oil sep just to be sure?
    Intel Core2Duo E6600 ES | Gigabyte GA-P35-DS3P | 4x 1GB TeamGroup PC5300 | ATI Radeon HD 3870 | Corsair 520HX
    Aug 2006
    Atlanta
    8
    Quote Originally Posted by Jack View Post
    Cant find an AB oil spec sheet...
    Never heard of a home built oil sep that was floated and I want it to be automated...
    Xtreme Member ultralo1's Avatar
    Oct 2008
    NC
    2
    Quote Originally Posted by sdumper View Post
    Specs:
    Gas Ethane r170
    My guess is no, but if you have the time it would be a good experment.
    Aug 2006
    Atlanta
    8
    I may do that next week...im tired of messing with a manual oil sep and i dont want to buy a second floated oil sep...
    Xtreme Enthusiast quintus's Avatar
    Oct 2004
    Crazypc.ro
    0
    Gas Ethane r170
    Because of this i would say that a oil sep is not needed, for that range of temps.
    Aug 2006
    Atlanta
    8
    Quote Originally Posted by quintus View Post
    Thats what im thinking as well...
    Im going to recover and remove that pipework Monday....
    Diablo 3! Who's Excited? [XC] gomeler's Avatar
    May 2005
    Boulder, Colorado
    1
    Quote Originally Posted by ultralo1 View Post
    Agreed.
    Aug 2006
    Atlanta
    8
    Im betting it will work...I have had a first stage with a txv down to -72c with r402 without issues before so i dont see this being any different really...
    -150c Club Member n00b 0f l337's Avatar
    May 2005
    NJ
    11
    Nature of the beast. Sometimes it's more that the temperature at -70C is going to be in the highside of the second stage, and you get freezing in the HX or captube, and not necesarily in the evaporator.
    Quote Originally Posted by Movieman
    Thanks for the compliment but unlike that bartender you mentioned I'm not sleeping with you no matter what you say!
+ Reply to Thread
