Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 51
Thread: Kingston HyperX LoVo 1866 @ 2250+ Mhz 1,5v !!!
  1. #26
    Dec 2002
    Sweden
    wez, everything looks fine, cpu mem on old mobo as mine, well done bios rev f8k?
    what memvolt? I suppose it is not v2,05
    Vishera 8320@ 5ghz | Gigabyte UD3 | 8gb TridentX 2400 c10| Powercolor 6850 | Thermalight Silver Arrow (bench Super KAZE 3k) | Samsung 830 128gbx2 Raid 0| Fractal case
  2. #27
    May 2004
    Aland Islands, Finland
    Quote Originally Posted by Tomasis View Post
    Hehe nah, 2.05v is for another pair of sticks :P
    1.75v for 1720 fully stable and 1.8v for the 1800 spi32m. Still on f8h, haven't had a chance to give f8k a fair go yet.
    http://www.techreaction.net/2010/05/...99-oc-testing/
    Asus Crosshair IV Extreme
    AMD FX-8350
    AMD ref. HD 6950 2Gb x 2
    4x4Gb HyperX T1
    Corsair AX1200
    3 x Alphacool triple, 2 x Alphacool ATXP 6970/50, EK D5 dual top, EK Supreme HF
  3. #28
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    I tested these sticks on my RIIIE and 980X
    There are some system limitation at the moment, but someone with P55 will make these fly for sure.
    Here is stock settings and 1.2985V 32M
    Here is CL 9 1000MHz 32M with 1.49725V
    Here is CL 8 1000MHz 32M with 1.55V
    Here is CL 7 1000MHz 32M with 1.749V
    So in my tests, these are doing ok, but nothing spectacular have been found or seen. These stick seems to like CL 8 most.
    If the price is good, these might be your choice.
    You are as good as your samples are!
  4. #29
    Jul 2010
    Berlin, germany
    Well, might be the layout of the PCB-but I have to say that the Clock7 performance is disappointing in my opinion-thank you very much for sharing, me and a good friend of mine thought about buying the lovos but for me the risk is too high after seeing these results
  5. #30
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    Quote Originally Posted by websmile View Post
    I think you need to wait, if someone can test these sticks on P55 or in different setup
    For some reason my CL7 tests need a lot of juice in here.
  6. #31
    Jul 2010
    Berlin, germany
    Both my STT 2200 as well as my ProjectX 2000 C7 need a lot less voltage for 1000 C8 and C9 as well-maybe itīs the X58 setup, but considering that the sticks cost about 160€ in germany Iīm not taking the risk-even if the sticks need less V on a different setup for 1000 C7-maybe the Lovo are wonderful 24/7 rams with their 1,35V 15000 specs but thatīs not what Iīm looking for so your results did help a lot-thanks again
  7. #32
    Aug 2004
    Jakarta,Indonesia
    i have kingston hyperx lovo 1800, does it have the same chip with the 1866?
    AMD Phenom II x6 1055T
    muscle power 2x2gb
    MSI 790FX-GD70
    Powercolor 5850
    WDC Black 500GB + samsung spinpoint 1TB
    Corsair HX850
    auzentech x-fi forte
    Klipsch Promedia 2.1 + AKG K99
    Logitech G5 + G15 + QcK Heavy
    sorry if my english its not good
  8. #33
    Jul 2010
    Berlin, germany
    Quote Originally Posted by barong View Post
    You might make a test- if they run 1600 6-6-6-20 at around 1,65V on your system, the chance the ICs are Hyper is 99,9%
  9. #34
    Xtreme Mentor
    Aug 2008
    Australia
    ^BBSE does that too, so its not indicative of Hypers only.
    Ci7 990X::Rampage III Extreme::12GB Corsair Dominator 1866C7GT::2 x EVGA SC Titans in SLI::Corsair AX1200::TJ07::Watercooled
    Ci7 920 3849B018::Rampage II Extreme::6GB GSKILL Trident 2000C9 BBSE::EVGA GTX580::Antec Signature SG850::TJ09::Aircooled w/TRUE 120X
  10. #35
    I am Xtreme
    Aug 2008
    Quote Originally Posted by CryptiK View Post
    spot on
    even the new 2000 6-8-6 ....can do 1600 6-6-6
  11. #36
    May 2008
    Decatur, GA
    Gotta be some really good BBSE to do 1600 6-6-6 on 1.65v.
    i7 4930K
    32GB Corsair Vengeance Pro DDR3-2400C10
    Asus Rampage IV Black Edition
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
  12. #37
    Xtreme Mentor
    Aug 2008
    Australia
    My BBSE kit does it easily, also did DDR3-1600 6-7-6-20 1T @ 1.535v.
  13. #38
    Jul 2010
    Berlin, germany
    Looks nice- my Team 2200 LV did 900 Cl6-8-6-18 1T with 1,5V- but no chance on 1600 Cl6-6-6 with 1,65
  14. #39
    May 2008
    Decatur, GA
    Well, the Tridents are a special case
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
  15. #40
    Sep 2008
    For some more P55 results try to see this review i did:
    http://www.octeamdenmark.com/anmelde...-.html?start=4
    Only with 1.65V
    If you have some settings you would like tested feel free to ask
  16. #41
    Dave's Mentor!
    May 2007
    montreal
    my tridents did 1800 6-8-6 1.65v alse bbse
    maximus IV extreme gtx580
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
    920 Batch# 3849B018 4.985ghz@1.52v gtx285 ftw sli
    OCZ3RPR1866LV6GK hypers
    dfi ut p35 rampage extreme
    gigabut p35c-ds3r bios suks
    gigabut x38-d6q dead thank god
    ballistix 8500 1240mhz@2.02v
  17. #42
    PIfection
    May 2006
    900 6-6-6
    1000 7-7-7
    should be a fairly safe indicator of hypers...
  18. #43
    Jul 2010
    Berlin, germany
    Quote Originally Posted by youngpro View Post
    900 6-6-6
    1000 7-7-7
    On Intel you are right- I answered the question with 800 6-6-6 because the user who asked has a 790 AMD chipset where even with an X6 it might be difficult to reach 900 Cl6 at 1,65V, and 1000 C7 on air are nearly impossible with a decent 1,65V
  19. #44
    May 2008
    Hungary
    Sorry for my bad english...really
    Xtreme 3D Team Hungary
  20. #45
    Oct 2007
    Budapest,Hungary
    Quote Originally Posted by toyone View Post
    we should restest them with the newer bios on my board.
    I7 920 D0 5362 1.627v
    980X retail 3003A258 - 6683mhz 1.85v
    ASUS R3X 265bclk
    ASUS R3BE 266bclk
    ________________________
    _______________
  21. #46
    Pie assassin
    Nov 2007
    Where lights collide
    The latest kingston HyperX 1866 LoVo are NOT elpida hyper ic anymore. the ones with hyper ic are 122.a00lf the ones without are 032.a00lf
    just fyi if anyone is still interested in these kits. i dont know what the ic is on the new ones... they are kingston branded.
    Current Status - Testing & Research
  22. #47
    Xtreme Legend
    Mar 2005
    Australia
    they are also going EOL too 1866 ones
    I am waiting for an email today for some clarifications on other LoVo models which may be Hypers. If i find something i'll let you guys know.
    Team.AU
    Got tube?
    GIGABYTE Australia
  23. #48
    Pie assassin
    Nov 2007
    Quote Originally Posted by dinos22 View Post
    im on the phone with kingston right now trying to figure out what ic are under these piece of garbageses *they are checking with the store room right now finding me the hypers to cross ship. their customer support is great*
    what is printed on the non-hyper ic is this
    Kingston
    50366254
    1019
    S2C
    D1288JELDP J9U
    MDA776000E
    any ideas? they dont clock well AT ALL.
    *edit*
    kingston in fountain valley california has NONE left in stock and they said its phased out.
  24. #49
    Pie assassin
    Nov 2007
    here is what i got in the mail today
    Hi Davis,
    We can not find any BOM# and match your old HyperX memory. However, one option is swap your 2 kits (4 memory sticks) with KHX2000C9AD3T1K2/4GX
    with same BOM# of course and the memory Spec is:
    4GB 2000MHz DDR3 Non-ECC CL9 DIMM (Kit of 2) XMP T1 Series (Compatible, Non-proprietary)
    Standard 256K X 64 Non-ECC 2000MHz 240-pin Unbuffered DIMM (DDR3, 1.65V, CL9, FBGA, Gold)
    This one has tall heat sink and it is not the low voltage (1.35v) as the ones you have.
    The last option is refund to you and please attach the proof of purchase (invoice/receipt) so I can set it up for you.
    If you have any other questions or concerns, please feel free to reply to this e-mail with full email history. Thank you for using Kingston on-line technical support.
    Best Regards,
    Kingston Technology
    Technical Support
    8am - 5pm Monday through Friday PST
    PLEASE INCLUDE ALL EMAIL HISTORY WHEN RESPONDING. Failure to do so may result in your email being delayed or going unanswered. Please check your email settings to make sure it's configured properly to include the history. Please DO NOT modify the subject line as it's needed for proper routing. Emails are normally responded within 24 business hours.
    Note: If you are sending or receiving attachments. To protect against computer viruses, e-mail programs may prevent sending or receiving certain types of file attachments. Check your e-mail security settings to determine how attachments are handled and check your "junk" folder to ensure emails are not being routed there.
    This email and attachment(s) may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
    from this email it appears the latest lovo kits are bdbg. and they dont have any at all anyways so...... yea.
    what would YOU do in this situation? I'm thinking refund as I AM entitled because they dont mix with the hyper ic lovos @ stock speed, voltage, and timings.
  25. #50
    Xtreme Memory Hoarder
    Mar 2010
    that's cool they are willing to refund the purchase price
    Quote Originally Posted by Hondacity View Post
    gskillllin it!
