I have been setting up my water coolng the past couple of days
the parts are:
-ek full cover WB for 5970 with nickel backpate
-ek mosfet WB
-ek full cover x58 motherboard WB
(all above in copper acryl)
-swiftect micro res
-swiftech xt cu block
-mist 120.2 radiator
-mist 120.3 radiator
-swiftech mcp 655 pump
-1/2" I.D tubing
all fittings are EK high flow 1/2" straigth.
fesser one (red)
flow order: res - pump - 120.3 rad - 120.3 rad -cpu -gpu - mosfet 1- mosfet 2 -motherboard block- res
when i filled the res and started the pump, i could not believe my eyes, the water was moving so fast i could not fill the res fast enough, i had to stop the pump and refill, after filling it as muc as i could, there was enourmous amount of air pockets in the loop.
after juggeling the case upside down sideways, every know directio known to man, i eventully got most of it out.
But when i run the system now it barley trickles water, i also notice about 1/2" difference in the res when i start , shut off pump. there is probably a last bubble trapped in the top radiator.
could this bubble act as a plug? I.E; the pump squeezes water agains the air pocket, compressing it, but not moving it? or have i simply overloaded the pump with too many components?
