Hi people,
You may have noticed in this thread http://www.xtremesystems.org/forums/...d.php?t=254657
that I was having lots of trouble overclocking.
I will try and explain this and keep it short.
Basically my settings that I found stable are the following:
285x13 = 3705MHz
CPU-NB ratio 9 = 2565MHz
Ram ratio 1:2.66 = 1520 (all timings on auto)
HT link ratio 7 = 1995MHz
All voltage auto except:
CPU voltage = 1.3V (shows as 1.39 in CPUID hardware monitor & in bios)
CPU-NB voltage = 1.25V
DRAM voltage = 1.621(shows as 1.65V in CPUID monitro)
I tested these settings on OCCT for 7 hours on CPU-Linpack and 7 hours CPU-OCCT. Linpack was set to 90% mem usage 64bit and the CPU mode was on medium data set with normal priority.
This morning I turned on my computer and while trying to boot windows I got a BSOD, Bad Pool Header.
I then returned all my bios settings to stock and restarted. The computer would get to just after the windows 7 loading screen and reboot with no error.
I then disabled C1E in the bios and windows shows my desktop for a second before rebooting. I re-enabled C1E and rebooted. Same problem, just see desktop for a second.
I rebooted again and then it went into windows with no issues.
I found it also restarts in a similar fashion with Ubuntu, but once is has gone into windows once, no problem.
The C1E has given me strange issues when running stock settings and I have always disabled it when overclocking.
Also as soon as I turn my RAM voltage to 1.651 in the bios the computer fails Linpack after about 3-30mins. In Hardware monitor its reported as 1.7V when set to 1.651 in bios.
Im not sure if these errors are do to the computer being cold. Its about 12-15 degrees celcius in the mornings.
Any ideas? Im tempted to give my supplier my whole system and let them check it out, but their building is probably heated and may not find any errors.
MSI 890FXA-GD70 Bios 1.6
AMD Phenom II X6 1055T
Apacer Giant II 2x 2GB DDR3 240-Pin DIMM, 1.65V [PC17600] 10-10-10-30-2T
MSI 8800GT OC 512Mb
Corsair H50 in push pull config
CM Storm case
