Right for the ram voltage thing, I am running 1.68V which reports as 1.71 in Hardware Monitor.
This was 11 hours stable when I was running stock CPU speed & RAM at 1600MHz.
I've just decided that I am going to aim slightly higher and if I choose to enable turbo core again I will just lower the multiplier. I did this so the HT link and NB could run at stock and I am just testing CPU.
Hope there is method in my madness though.
Ok, this is what I am in the process of testing:
250x14 = 3500MHz @ auto (reports as a steady 1.38V under load)
HT Link x8 = 2000MHz @ auto volts
NB x8 = 2000MHz still @ 1.19V
RAM multi set so RAM is now 1333MHz still @ 1.68V
If this works I will then try bumping up the NB multi and test again.
Once again I am off to work, so I won't really know results to later.
I think tomorrow I will just take my PC with so I can monitor it there.
