Page 3 of 6 FirstFirst 123456 LastLast
Results 51 to 75 of 131
Thread: XFX at it again; Warranty Denial.
  1. #51
    Jul 2009
    Philippines
    LOL @ Quad-Damage.
    Take the trip! It'll be like what Valve did for the L4D2 haters!
  2. #52
    Jan 2010
    Sorry for your difficulties, but thanks for the heads up. I was looking for an ATI card (since BFG doesn't make em) and XFX is now off the list. Last thing I need is a company that looks for reasons to deny warranty. IMHO - their reasoning was insufficient.
  3. #53
    Xtreme 3D Team
    Jan 2009
    Ohio
    Quote Originally Posted by DTR View Post
    Pretty much leaves you with MSI or ASUS.
    Smile
  4. #54
    Xtreme Mentor
    Sep 2006
    Quote Originally Posted by Ket View Post
    That reply to me seems like something XFX has said because their desperate to try and repair their severely diminished reputation. They were good once, not since the 7800 fiasco days My gut tells me if that reply is real it'll be a stunt. Make it look good on the surface, you may end up with a new card. Would be much less effort and expense on their side if they just sent you a damn replacement card.
    Of course it's a stunt. Straight up PR. I really hope he doesn't sell out and just demands for what is rightfully his.
    For my part I know nothing with any certainty, but the sight of the stars makes me dream.
  5. #55
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    Quote Originally Posted by BeepBeep2 View Post
    dont forget biostar they just started in mass but they only have reference 5850/5870 (or did last week, i havnt looked again) and they are priced cheap since they are not well known in the market.
    on topic, if they offered to take me to the factory or rma center i would go for it, sure its just a pr joke but it could open doors for employment and i would be that they would replace your card, or u got coolant on the card and let it dry and they know it but that dose not seam reasonable but if u got a tampered box it could have happened.
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
  6. #56
    Sep 2004
    I was about to order another HD5850 for my xfire. Saw the cheapest one from Newegg is XFX. Since I have never dealed with them before, so I came here and see if anything about them. So I went ahead and ordrered the Shappire. Even thought it is more expensive, but I have a good history of RMA with them before. No matter how cheap is the product. If the product support is sux, it's not worth it to spend my money on it.
    Good luck with your case man...
  7. #57
    Jan 2010
    Here is something interesting - and if Dell can do it - so can XFX:
    "Dell blamed the college for overtaxing the machines, but newly released evidence indicates that the failures were actually caused by faulty electrical components that leaked chemicals."
    Kinda sounds like that's the residue they found on your card, under the HS. It could likely be and reasonably sounds like a flaw in materials / workmanship to me.
    Link to Dell story: http://www.dailytech.com/Built+to+Fa...ticle18884.htm
  8. #58
    Jul 2007
    SF bay area, CA
    its not like xfx makes any of their cards they just order them with their bios, red dvi ports and their sticker. dell is the same, they order there boards, and they get them and put the computers together, sure they knew that the boards were bad and it wasnt shown if they picked those parts or if those parts were the cheapest that made the spec but if selling parts u know are bad gets dell a large fine and some consumer action, that should get the same to NV with every IGP they have made, the low/midrange 8xxx and some 9xxx from the rebadges and the 680/780i boards that were ROHS compliant and the OEMs that sold them as they had a huge failure rate and were sold even though NV, oems and verdors knew that they were all bad. or the power supplies that HP uses that die affter 6 months and burn up emitting chemicals.
    sure all of those fit in with that but its not really anything that is new or different, they should have just replaced it if thats the only spot its in, and it was under the heatsink, especially with the plastic tab was still attached from the card to the HS and the crap thermal paste was still there. but they cover removing the heatsink and that is clearly a defect from the factory or liquid cooling coolant.
  9. #59
    Nov 2007
    I had a bad experience with XFX before this for my GTX 285 Black Edition. The card died and I've never did anything to it (everything was stock) but they claim there were burnt marks which I've got no idea what happened. They refused to honour the warranty and after a long argument (for weeks), the local supplier gave me a GTX 280 (used) as a replacement. Totally doesn't make sense and I would avoid this brand at all cost in future.
    Intel Inside
  10. #60
    Dave's Mentor!
    May 2007
    montreal
    Quote Originally Posted by MDboyz View Post
    they cheaper only cause they cheaped out on pcb n components
    they makin more $ even sellin it cheaper
    maximus IV extreme gtx580
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
    920 Batch# 3849B018 4.985ghz@1.52v gtx285 ftw sli
    OCZ3RPR1866LV6GK hypers
    dfi ut p35 rampage extreme
    gigabut p35c-ds3r bios suks
    gigabut x38-d6q dead thank god
    ballistix 8500 1240mhz@2.02v
  11. #61
    Jan 2010
    Quote Originally Posted by zsamz_ View Post
    they cheaper only cause they cheaped out on pcb n components......
    And becuase they don't have any expenses warranting the cards. - You know how cheap cars would be if you didn't have eat warranty costs for the first 3 yrs.
  12. #62
    I am Xtreme Ket's Avatar
    Apr 2004
    United Kingdom
    I wouldn't say XFX cheap out on the components their cards use, my 4830s allow for the highest voltages I've seen from non modded cards (1.258v) and now the cards have a good BIOS on them, they clock well (710/2200) I think they just don't have any warrenty worth more than the paper its printed on.
    "Prowler"
    X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
    Cooling:
    6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
    Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
    Modded X570 Aorus UEFIs
  13. #63
    DySfunCtiOnal MeMbEr
    Nov 2007
    Lost
    I'm glad I seen this... I was about to order a few XFX cards.... Not anymore..... Thanks for the info...
    Windows 7 64 Bit
    BenQ FP241W Black 24" LCD
    Mountain Mod Case w/ Base
    Asus Rampage III Black Edition
    i9-990x @ 4.58GHz - 1.36v Temps (Idle 23C - Load 48C)
    12GB Corsiar Dominator GT (PC3 15000) @ 9-9-9-24 1T - 1.65v
    Sapphire 5870 x3 "OC" w/ EK Water Block Temps (25C-49C)
    EK-Supreme / 4 Alphacool Laing DDC-Pump Ultras + Extras
    Power Supply / 2x Silver Stone DX1000
    Western Digital 1.0TB x 3
    Crosair SSD 128GB x 2
    World Community Grid!
  14. #64
    Apr 2004
    United Kingdom
    Stay away from Sapphire, their not too hot either. Go with Powercolor, Asus, Gigabyte, or anyone like that. Had good experiences with all of them.
    "Prowler"
    Cooling:
  15. #65
    Nov 2007
    Lost
    I've used Sapphire and Powercolor a few times without any issues..
    Windows 7 64 Bit
  16. #66
    Apr 2004
    United Kingdom
    Sapphire aren't a good company really. Their RMA can be compared to the XFX RMA.
    "Prowler"
    Cooling:
  17. #67
    May 2008
    Gotta second this, I have had a terrible experience dealing with Sapphire every time. Then again, I can't name any company I have had an "excellent" or "awesome" experience with when it comes to hardware RMA. They all suck!
    Phenom II X4 965
    MSI 790FX-GD70
    G.Skill ECO 1600CL7
    Radeon HD 4850 Crossfire
    150GB Raptor OS drive
    2x500GB Hitachi data drives
  18. #68
    Jul 2007
    SF bay area, CA
    sapphire sucks they wanted to charge me $15 to beable to rma and then they also wanted me the pay shipping, the only companes that ive had good rmas with were ocz, corsair (in person), dfi (in person), and logitech. dfi and corsair replace your item in person u just get an rma number call up and say that u comming and they replace it right there, logitech gave me a g500 to replace my g5 that had a side scroll broken and they did not want the g5 back so i have a spair mouse that has no side scroll but thats not all that useful
  19. #69
    Jan 2010
    BFG Tech has great RMA (the one time that I needed it) .... My 8800GT went bad and they sent me a MaxOC_260GTX as a replacement - lifetime on the cards. Too bad they don't make ATI chipset cards as I'm not putting a nuclear heat generator (470/480) in my rig / office.
  20. #70
    Banned
    Nov 2005
    Acreageville, Alberta
    So. Any real word on where this has gone??
  21. #71
    Nov 2007
    Lost
    Quote Originally Posted by turtletrax View Post
    Probably not too well….
    Windows 7 64 Bit
  22. #72
    Banned
    Nov 2005
    Hmmm, I was just wondering if I should start buying other cards. I mean, I have 3 registered XFX 5870's ,and 5 out of my last 6 cards have been XFX, but if this what I can expect I will gladly start buying others.
  23. #73
    Xtreme Enthusiast Aedubber's Avatar
    Oct 2009
    TX
    Damn man that sucks, seems like they just didnt care and honestly if these companies were any smart they would tag the screws directly from the shop once put together. If you look at your cars motor, you will see a few screws that have what seems to look like a stripe on the nuts and bolts etc. This is how dealerships can tell wether YOU tampered with an air box , valve cover, the head , some other areas of the engine bay etc . Its just such a shame these companies treat you the way they do while spending hundres if not thousands of dollars with them. Hopefully better luck next time mate!
    HEATWARE
    x58-UD5 ▀▄ i7 950 4.0Ghz ▀▄ ZOTAC GTX 580 ▀▄ Mushkins 1600Mhz
  24. #74
    Oct 2004
    London UK
    I know this is an old thread but a link from a new XFX thread got me here. We never did hear what happened.... Here was the reception team for NCspecv81
    Respec'
    System:Bunch of crappy overclocked PC's that cost an arm and a leg
  25. #75
    Dec 2008
    I'm glad I saw this topic as well, been looking at getting the XFX 6950's. Think I stick with HIS.
    [SIGPIC][/SIGPIC]
