+ Reply to Thread
Results 1 to 2 of 2
Thread: power supply
    May 2010
    0
    power supply
    hi all. i sprayed my power supply and i want to know what are those in red box.. i remove the plug so i can spray power supply case .am trying solder it back on but having hard time doing it.. is it ok to just solder the 3 wires back on positive,neutral and earth with out them ?....
    <script src='http://img139.imageshack.us/shareable/?i=141sc.jpg&p=tl' type='text/javascript'></script><noscript></noscript>
    Last edited by michael27; 06-22-2010 at 12:52 PM. Reason: [URL=http://img139.imageshack.us/i/141sc.jpg/][IMG=http://img139.imageshack.us/img139/2972/141sc.th.jpg][/IMG][/URL]
    Xtreme Member rakesh_sharma23's Avatar
    Oct 2008
    0
    These are the component of Transient Filtering Stage.
    The two ceramic capacitors seems to be dead. This is cos there might be some sort of earthing problem in the wall socket or loss wire connection.
    Just replace the two ceramic capacitors as they are with new ones and also check the power fuse, if it's also blown just replace it too..
    May be this can solve the issue.
+ Reply to Thread
