Hi guys,
I noticed some people have the MIPs ram cooler with the clear tops and the nickel plated base. I have searched google and can only find the black acetel versions, are the acrylic/plexi versions custom made?'
Many thanks in advance!
Mudgey
Hi guys,
Mudgey
IIRC there were at least two guys that had made such custom WBs. One was Duniek, another one was some friend of Screamer called Barus. I've seen Duniek's ram blocks in several builds.
Yea they did look damn good. I think i'll have a go at making one myself!
Maybe!
I've done a quick model for costings purposes and will see if its viable!
Nice. Cooling channels/fins for more cooling area?
All stock for now, no need for more, but it's gonna be soon methinks.
Giga Xtreme 58 mobo i7 965 ES D0 step Corsair 1600 6 gig
SLI GTX470 EVGA
EK HF nickle blue top CPU block (free from Eddie)
Koolance 470 waterblocks
One big loop, two 120x3 rads. Pa 120.3 and XSPC RX 120x3. Swiftech 35x pump with V2 restop. GT AP15 fans.
Banchetto Tech Station
120 GB SSD, and a few other drives.
1000W UltraX3 PSU, 900 watt (1500VA UPS
23.999" Acer GD235hz and 24" Acer H243H
I've been hoping something like this would become widely available in the US...
My first/current build:
Components/OS:
Case: Corsair Obsidian Series, 800D
CPU: Intel Core i7 920, D0
Motherboard: EVGA X58 Classified 3x SLi, E760
RAM: Corsair Dominator-GT, CMG6GX3M3A2000C7
PSU: Enermax Revolution85+ 1050w
GPU: EVGA GTX 480 SuperClocked
PhysX: MSi 9800 GT OC2
Network: VisionTek Killer 2100
Storage: Intel X25-M 80GB (Boot), WD Caviar Black 1TB x2, Seagate Barracuda 1.5TB
OS: Microsoft, Windows 7 Ultimate x64
Cooling:
CPU Block: Watercool HeatKiller Rev. 3.0 Cu, Watercool 1366 backplate
Chipset Block: EK-FB EVGA X58 Classified, black acetal+nickel
GPU block: Bitspower Black Freezer, BP-VGNGTX480-MBK
Radiator: Hardware Labs Black Ice SR-1 360mm
Pump: Laing DDC 3.25
Reservoir: XSPC acrylic dual 5.25" bay for single DDC
Tubing: PrimoChill PrimoFlex PRO LRT 1/2" ID 3/4" OD, non-UV white
Fittings/Fasteners: Bitspower 1/2" ID barbs and rotary angles, matte black. Nylon click clamps, black
PhysX GPU Cooler: Arctic Cooling Accelero S1 Rev. 2
Ram Cooling: Corsair extended fins, CMXTRFINKITRED
Fans: 120mm - Noctua NF-P12 w/ U.L.N.A. x4. 140mm - Noctua NF-P14 w/ U.L.N.A. x2
Thermal Compound: Arctic Silver-5
Other: Distilled Water, coiled 14g 6" 99.99% silver
I am currently enquiring about pricing as machined part costings are new to me, unfortunately I can't guestimate what certain levels of detail cost.
I have added machined channels for greater surface area, however I will ask how much extra this may cost once I get back the first quotation.
I shall redraw the block as the end hole positions look a bit lost, and I want to reduce the number of cap heads to 6 to reduce costs.
I need to source a supplier for the o-rings and then I can redraw the channel to the o-ring length.
Can anybody recommend what grade of material is suitable for an o-ring for our WC applications?
Conumdrum: why for? RAM as it is dissipates very little ammount of heat, why add extra restriction for waterblock to increase cooling where it's not needed by same time worsening cooling where it matters - in other waterblocks in loop via less flow? Also making block more difficult to make, requiring extra tooling, taking more time? As marketing droid might tell you - it's "Loose-loose"![]()
“Little expense had been spared to create the impression that no expense had been spared.” - Hitchhiker's GuideMondays:It's better to ask dumb questions now, than to look stupid later
There is probably no need to add channels to the copper block, nor is there any need to add channels to the acrylic as these will just add to the cost.
This is much better than the mips one. because
1 it's FAR less restrictive than the mips one
2 it has a acrylic top !
i wouldn't bother with channels rams puts out no heat basically
o rings are the best ways of sealing a block epically when looks are important
I like it.Watercooling ram with radiator cooled liquid is completely useless though but hey, it looks great.
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
SLI GTX470 EVGA
IMO- if the 'fins' were cut/added to the acrylic, they would glow nicely under colored lighting ... being on edge, contacting the inner surface an all... would add a nice touch
*I think the MIPS was originally made for ECC setups which generate massive amounts of heat compared to standard desktop type memory.
Hi Dathbeavis,
I will be sticking with o-rings as I won't be producing these coolers at the same qty's as the aforementioned company's products plus the simplicity of the shape required means that an o-ring will suffice.
I have attached another render of the finalised design (albeit one or two slight dimension changes).
Production prices are pretty cheap, and I am currently awaiting on some prices for two or three prototype blocks to be made.
DB, so far you've only shown pics of DD using gaskets. That's not companies, that's company. Any other manufacturer you know of that uses gaskets? (just wondering)
