Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: Overkill home networking?
    Wuf
    Jul 2007
    Finland/Tampere
    Talking Overkill home networking?
    Ok, i found a true bargain deal from local computer store, used 1U network switches for 25€/piece.
    There was couple of normal 100Base-TX switches, between 16-48 ports but there was one 24p 1000T-Base switch! Like i could resist, over half krand switch going for mere pocket money.
    Ok the switch is HP Procurve 2824 J4903A, and it seems to work, console responds, web gui works, works as gate way. Only thing i don't like about the switch is that it has 3 40mm fans
    I'll add some pictures in a minute.
    bad angle.
    You use IRC and Crunch in Xs WCG team? Join #xs.wcg @ Quakenet
    [22:53:09] [@Jaco-XS] i'm gonna overclock this damn box!
    Ze gear:
    Main rig: W3520 + 12GB ddr3 + Gigabyte X58A-UD3R rev2.0! + HD7970 + HD6350 DMS59 + HX520 + 2x X25-E 32gig R0 + Bunch of HDDs.
    ESXI: Dell C6100 XS23-TY3 Node - 1x L5630 + 24GB ECC REG + Brocade 1020 10GbE
    ZFS Server: Supermicro 826E1 + Supermicro X8DAH+-F + 1x L5630 + 24GB ECC REG + 10x 3TB HDDs + Brocade 1020 10GbE
    Lappy!: Lenovo Thinkpad W500: T9600 + 8GB + FireGL v5700 + 128GB Samsung 830 + 320GB 2.5" in ze dvd slot + 1920x1200 @ 15.4"
    Xtreme Cruncher
    Dec 2005
    L.A. ( Latin America)/ 4socket wannabe
    bastagge thats a f.. deal.. spend 50 euros in replacing the 40mm fans with noctuas
    "Study hard my young friend"[/B].
    Woody: It's not a laser! It's a... [sighs in frustration]
    Wuf
    Jul 2007
    Finland/Tampere
    Quote Originally Posted by Duh View Post
    Hehe yepp, those fans are quite noisy. So i'll A, get those little adapters that lower fan voltage or B, get entirely new fans or C something between
    I need to test does that switch even boot with one or more fans missing.
    Ze gear:
    Xtreme Mentor
    Jun 2008
    France - Bx
    HP Procurve 2824 J4903A for 25€
    That's totally amazing
    Wuf
    Jul 2007
    Finland/Tampere
    Little modding.
    Old loud fans
    New queit fans and i should say that it will cool a lot better that with orig fans. :P
    Ze gear:
    Jul 2005
    Now wire your house for fiber and you are set.
    Wuf
    Jul 2007
    Finland/Tampere
    Quote Originally Posted by MrMojoZ View Post
    Haha that'll cost a arm and a leg... About half a million is not that far away :P
    I think i'll place this next to ADSL modem and get cheap 5p 1000Base-T swich to my room, this way this setup isn't so overkill =P
    There's some interesting setup options in this switch, set ports on/off, manage and limit they speed (possible to set ethernet connection to 10Base-T etc), Virtual Lan, it'll report anykinda crc errors in connection and such.
    This thing rocks ecept for power comsumtion, it's around 50W :x
    Ze gear:
    Aug 2009
    Finland
    There is no such thing as overkill and you should know it
    mato78.com - Finnish PC Hardware news & reviews
    Wuf
    Jul 2007
    Finland/Tampere
    Quote Originally Posted by puunakki View Post
    Yep.
    It isn't a overkill if it works.
    Ze gear:
    Xtreme Cruncher
    Dec 2005
    can you get another of those? a MJ12 ( a crazy Dutch crawler) friend has requested me if he can get one of those biatches for cheap
    Aug 2009
    Finland
    There isn't more I would've wanted one too
    Wuf
    Jul 2007
    Finland/Tampere
    That was the only gigabyte ethernet switch :/
    Ofc there was couple of 20p switches and one 48p =P
    Ze gear:
    Xtreme Cruncher
    Dec 2005
    Quote Originally Posted by s0lid View Post
    many thnaks
    gigabyte or gigabit? :P
    btw, do you have model numbers available?
    thanks
    Wuf
    Jul 2007
    Finland/Tampere
    many thnaks
    thanks
    gigabit ofc, my bad
    Err only one i remember is Extreme Networks Summit 200-48.
    Ze gear:
    Xtreme Cruncher
    Dec 2005
    most likely that one is gonna cut it as he "only" has a 120 megabit connection
    Nov 2009
    Canada
    It's not overkill unless you're going for 10G connections in your home.
    Xtreme crazy bastid
    Apr 2007
    On mah murder-sickle!
    It's not overkill if it gets the job done. Then it's "just-enough-kill"
    [SIGPIC][/SIGPIC]
  18. #18
    Wanna Pull My Finger?
    Sep 2007
    Oklahoma
    I love my gigabit router, I've got two systems with gigabit connections and file transfers between them are incredible!
    Donate to Xtreme Systems!
    Now Showing:
    Gigabyte x48-DQ6, Q6600,OCZ 1066 Reapers,2 750gb seagate 7200.11 hd, BFG 8800GTS 512,PC P&C 750 Quad psu, 24" Sceptre lcd, Antec 900
    my wife's system now!
    Intel C2D 6400, Zotac Matx mobo, 1gb kingston mem, Nvidia 7050, I Feel really Good now!
    Jon C2D 6600 Zotac mobo 1gb mem............................................... ................. HTPC qx6700@3.0ghz
    Annabelle Amd 3800+@2.4ghz, Biostar mobo, 1gb ocz pc4500 beta's................. Optyx2 opty165@ 2.1 ghz
    'Want a real high?
    Come crunch WCG and you'll feel like your on QuadCaine"
    First loops are like first sex, all hands and thumbs till you figure out what goes where, then it's what ever works best for you.
  19. #19
    Wuf
    Jul 2007
    Finland/Tampere
    Quote Originally Posted by Necetra View Post
    Hehe, that'll cost more to get here than i earn in my whole life.
    Quote Originally Posted by fart_plume View Post
    Just ran test with my lan rig (copied all the new stuff i grabbed at lan party) about 20gigs changed computers under 2mins! peaked at 110MB/s still switchs status monitor tells me i used only 70% of the possible bandwith!
    Ze gear:
  20. #20
    Wuf
    Jul 2007
    Finland/Tampere
    Making new cover for procurve.
    Still need to sand it alot and add 2x 120mm fan holes there :P
    And don't mind the color of that plexi, only picked it because that was dirt cheap. 1.5x2m piece did cost like 10e.
    Ze gear:
  21. #21
    Fanboy of Good Products
    Oct 2008
    FL
    ok i'm gonna be real honest here, i'm a total networking noob. what does this awesome network switch do for ya?
    Cruncher #1: EVGA Z68 FTW | i7-2600k @ 4.5 | 6GB Ram
    Cruncher #2: Supermicro Dual-Socket | 2 x 6-core Opterons | 4GB Ram
    Cruncher #3: 8-core Xserve 1,1
    T400 for non-crunching
    "But don't think you'll run me over - It's, ah, planting season here in Texas... and the farm is growing..." -Otis11 on crunching WCG
  22. #22
    Wuf
    Jul 2007
    Finland/Tampere
    Does this houses internets haring between computers and maintaining gigabit lan, nothing fancier
    And here's the final product :]
    Cool and silent.
    Ze gear:
  23. #23
    Xtreme crazy bastid
    Apr 2007
    <Sean Connery>
    Shecksee!
    </SC>
    [SIGPIC][/SIGPIC]
  24. #24
    Xtreme Cruncher
    Dec 2005
    American version: NAAAAIZZZ ( nice)
  25. #25
    Oct 2008
    FL
    don't forget dust filters
