Since I'm finally going off to college (postponing it for 3 years now). I decided to break down my bench rig and throw it in my Stacker 830.
Components:
Classified 760 (3 way)
3gb PI blacks
250gb HDD
285 Classified
1k ToughPower
WC:
HK 3.0
Mo-Ra
2x DDC
EK Dual Top
1/2" Tubing
Case:
Stacker 831
What needs to happen
1. Cut holes for CM
2. Sand the case down
3. Throw some primer on it
4. Sand some more and primer
5. Paint the case black and white
6. Rivet the case back up
7. Install hardware
8. Layout watercooling loop
9. Sleeve everything black + white + red
10. Plug everything in and take pics
This is the case but mine is all black even on the inside
Case De-Riveted
6/1
1st coat of primer on the tray
6/2
Rad + 760
6/3
Fitting mobo to tray
2 coats of flat black on the tray, i still need to paint the white ( its just primer).
bought some paint
6/6
Tray is almost done, just need to clear coat
Just for fun pics
6/10
