So i've just built my first WC setup:
Swiftech MCP355 (Laing DDC) 18 Watt version
XSPC Res & pump top replacement
Swiftech MCR320 QP rad
XSPC Delta V3 cpu block
Swiftech MCW60 gpu block
Tygon R3603 7/16 ID
All DD Fatboy 1/2in barbs
There is a mismatch of fans on the rad. A high speed Silverstone, and Antec SmartCool, a couple of cheap CoolerMasters (IPC Queen), and a couple of no name (at least i can't remember what they were) fans pulled from old PCs. Not the most optimal setup, but thats six 120mm fans in push-pull, and the MCR320 QP cools well on low speed fans, or so i've read.
I'm running my I7 920 D0 at 3.8Ghz/190Bclk with +70mv Vcore (about 1.25 with vdroop enabled on my Bloodrage). QPI/VTT, Uncore, and all other voltages are default. After 20min of Prime95 SmallFFT Priority 8 i'm getting core temps of 71/69/69/64 with an ambient temp of 75f (about 24c).
Running OCCT for 30min produced 76/73/74/69 with ambient temps of 84f (about 29c).
Are these good temps? I know a good block like the heatkiller can lower delta temps about 10c compared to this block, at least according to testing by HESmelaugh. (I believe thats who ran the block tests anyway). I was running out of money though and there were certain things i didn't want to skip on. I read this block performed well for the money so i settled on it. I figure i can replace it later if need be.
I haven't ran anything but the stock cooler and my water setup on this i7 so i don't have much to compare it to. I thought about testing out my Ultra 120 i used on my Core2 but i don't have the 1366 hold down bracket and don't really want to spend the money on one. Though i am curious as to what kind of temps it would give me.
What do you guys think? Good temps or bad? I've done one remount with the block and didn't notice any difference. I'm using AS5 TIM.
Also, since core 1 and 4 vary so much from each other i'm wondering if i should do the RealTemp calibration as per the instructions? It looks like everyones varies by some degree, but i'm wanting to push this cpu a little further, and i don't want temps to go over ~75c. Problem is when core 1 hits 76, core 4 shows 69. Which should i go by?
