Sorry, I just meant you would need to remove your SSD to format on another system, OR format it on your current one with the install CD
Glad to see you got it all sorted out now!
FYI, TRIM will work in IDE or AHCI mode, but AHCI mode will be better for performance.
You can switch back and forth between IDE/AHCI and RAID if you want, just make the following registry changes first
Enable switching between all IDE/AHCI/RAID modes by changing "Start" Values in these keys to 0
Code:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Msahci\Start
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Pciide\Start
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\iaStorV\Start
