I have a coolermaster cosmos s running a GTX295 GPU on a classified MB with a core i7920 at 3.6GHz watercooled.
The 240mm rad is situated at the top and has 2x gentle typhoons pulling the air through the rad from ouside the case.
There i a standard 240mm fan pulling in air at the front, 1 magma pulling air in through the bottom and 1 magma as an exhaust at the rear.
There is also the cosmos s 12inch fan on the side acting as an exhaust too but it only runs at 700rpm.
My problem is my GPU has at had TIM and new thermal pads but it idles at 54C and 85C full load.
I have a feeling the case is it to hot internal.
How can I fix this, thanks.
Some pics:
