Raptor Sata Problems Help Plz
heyhey,
i jsut got a raptor 36.6 10k rpm . i have an ic7max3 mobo (if anyone of u have one theres 2 sata plugs and 4 more at the bottom . i know the first drive u got u plug in plug 1 or 2 but it confuses me cause on lpug 2 it says sata 1 and plug 1 sata2 ... ) well thats not the main question . my main question is that i have an ATA hdd that i would like to put as slave but even in slave windows always boot from it cause its IDEMASTER1 and raptor IDEMASTER4 . so i was oh well ill remove my HDD then plug my cdrom on ide1 and burner on ide2 and my raptor ide4 . but then i format and install windows but it still does same prob like its trying to start from idemaster 1 ... so u know how ic an change proprites so it boots from ide master 4.
hmm if u need specs of my comp its : ic7 max3 , p4 2.4c@3.2 , khx3500 , and an other maxtor 40gb ATA .... hope u help :P
thanks.
Xtreme Guru
just go in bios, basic CMOS settings, and set the raptor the first one and the IDE1 the second one.
oh ok thanks it works now
Xtreme Guru
fun!!!!!!!
- You may not post replies
- You may not edit your posts
Forum Rules
