Results 1 to 18 of 18
Thread: need advice on high flow block for 5970
    Jul 2006
    norway
    first off, my rig is in the sig
    i have a mist water cooling set on order, parts can be seen in this link:http://www.microplex.no/Avdelinger/D...366-40304.aspx
    now i could use a gpu block for my xfx 5970, that does not restrict the flow (too much).
    also; do i need another radiator if i throw my gpu in the loop, if so what size is needed?
    Asus Rampage II Extreme
    intel i7 930 @4.3 ghz
    12 GB patrot pdp 2000 EL 3x4 bg @ 821mhz, 8-9-8-24 1T
    XFX 5970 black edition @ 950 | 1200 (shappire bios)
    240 GB Vertex 3 MAX iops OS disk | 2x ocz agility 60gb in raid0 128k stripe size | 2x wd black 1 TB in raid 0
    win 7 Home Premium 64 bit
    coolermaster haf 932
    Corsair HX 1000 psu
    ASUS VG236H 23-inch 3D Display 120 hz
    cooling:
    ek full cover WB for 5970 with nickel backpate
    -ek mosfet WB
    -ek full cover x58 motherboard WB
    (all above in copper acryl)
    -swiftect micro res
    -swiftech xt cu block
    -mist 120.2 radiator
    -mist 120.3 radiator
    -swiftech mcp 655 pump
    Apr 2008
    most if not all full covered gpu blocks will not restrict the flow much, and yes you most definitely need at lest another 240 rad for the 5970 .
    Jul 2006
    norway
    thank you for the reply
    a 240 radiator is noted.
    the shop where i orderd my water cooling setup did discurage me from ordering the aqua computer block as seen here: http://shop.aquacomputer.de/product_...oducts_id=2409
    now, danger den is supposedly a high flow full cover block, but where i live (Norway) there seem to be no local dealers :/
    Corsair HX 1000 psu
    cooling:
    -ek mosfet WB
    -swiftect micro res
    Jun 2003
    Singapore
    My setup is pretty similar to yours. I'm using the XSPC full cover which works out pretty well for me. At 900MHz and 1.157v my idle temp is around 35c and load to around 50c on Furmark. Its a cheaper and very simple block. Another option is the EK block which most ppl here use. With the EK block you have the option to get the back plate which looks good and seems useful as the ram at the back of the card runs pretty hot and its also part of the reason I couldn't get my ram above 1200MHz.
    Gaming/General Usage | Win7 64
    Gigabyte GA-X58A-UD7
    I7 930 (3003A965) @ 4.2 (200x21; CL7-8-8-24/1600; VCore=1.35V)
    OCZ3F1600LV6GK 6Gb
    PowerColor 5970 @ 900/1110
    X25M 80G G1 X2 Raid0, Xonar D2X, Antec 1000W.
    Swiftech Apogee XT
    EK Waterblocks EK-FB KIT
    XSPC 5970 Full
    Swiftech MCP655
    Feser X-Changer QUAD 480
    EK-Multioption RES X2 - 150 Advanced
    Scythe GentleTyphoon 120, TJ07
    Apr 2008
    +1 for EK on the basses of looks . all the other FC blocks will preform the same + - 1~2c .
    Oct 2008
    Guam USA
    +1 for EK 5970 Nickel/Acetal with EK Backplate.
    EK Blocks Are Awesome!
    |Asus Rampage III Gene Bios 805|i7 980X|12GB Corsair Dominator 1600C8 w/EK Nickel+Acetal Dominator Ram WB|XFX HD 5970 Black Edition+5870|OCZ 1010 GameStream|Windows 7 Ultimate(64bit)|Corsair F-60 SSD w/ 2TB Seagate HD|EK-FB R3Gene Nickel+Acetal(Fully working) & Asus-1 WB|EK Supreme HF Full Nickel Edition|EK 5970 Nickel+Acetal, XSPC 5870 FC w/ EK Backplate|XSPC RX360+Black Ice Stealth 120+MCR120, D655,XSPC Acrylic Dual 5.25 Res for D5 |Coolermaster Cosmos S w/Sidewindow|3 Samsung 205Bw LCDs in Eyefinity
    Dec 2004
    Novi Sad, Serbia
    "waterblock pron"
    Jul 2006
    norway
    thanks alot for the advice, EK it is
    Corsair HX 1000 psu
    cooling:
    -ek mosfet WB
    -swiftect micro res
    Jul 2006
    norway
    oh boy... this turned out more expensive then i planned
    but anyway it is orderd, threw in a few more pices, since i have gotten so far:
    from order recipt:
    1 c_prod_5 EK-10mm (3/8 inch) G1/4 High-Flow Fitting 0.00 0.00
    1 c_prod_3 EK-FC5970 0.00 0.00
    1 c_prod_4 EK-FC5970 RAM Backplate - Nickel-Plated 0.00 0.00
    1 c_prod_2 EK-MOSFET ASUS X58 KIT 0.00 0.00
    1 c_prod_1 EK-FB RE2 0.00 0.00
    Corsair HX 1000 psu
    cooling:
    -ek mosfet WB
    -swiftect micro res
    Jul 2004
    Did we ever come to a conclusion as to which 5970 block had the best VRM temp performance? Also, how does thee Koolance rev. 2 perform?
    Jul 2006
    norway
    id like to ask one more stupid question; when choosing a tim to paste on the gpu, i see a lot of people useing non conductive glue like compunds.
    would i go horribly wrong if i use my coollabratory liquid ultra to smear on the cores? as i m taking the cost to liquid cool about everything on my pc, i feel like i am gimping myself by using something like ceramique.
    Corsair HX 1000 psu
    cooling:
    -ek mosfet WB
    -swiftect micro res
    May 2004
    Aland Islands, Finland
    Quote Originally Posted by djustice View Post
    Just make sure it doesn't spread out to sensitive parts around the gpu core Can dab some nail polish on the closest resistors if you want to be extra safe
    Asus Crosshair IV Extreme
    AMD FX-8350
    AMD ref. HD 6950 2Gb x 2
    4x4Gb HyperX T1
    Corsair AX1200
    3 x Alphacool triple, 2 x Alphacool ATXP 6970/50, EK D5 dual top, EK Supreme HF
    Apr 2010
    i thought the swiftech 5970 waterblock is supposed to be better performing than the Ek blocks???
    Jul 2006
    norway
    i mostly orderd the EK gpu block for the backplate (ramcooling)
    but to be honest i did not look at swiftecs solution to cooling the backside of the 5970.
    Corsair HX 1000 psu
    cooling:
    -ek mosfet WB
    -swiftect micro res
    Jul 2006
    norway
    parts have arrived
    http://www.glowfoto.com/static_image.../img4/glowfoto
    now, i plan to run this and the swiftec gtx cpu block on one loop, so far i have 1x highflow 240 radiator and a mcp 655 pump, guess i really should get another 240, or maybe even a 320.
    i see peope recommending 2 pumps and run seperate loops, but is it possible to run all this with one pump in one loop?
    Corsair HX 1000 psu
    cooling:
    -ek mosfet WB
    -swiftect micro res
    Jan 2010
    Trinidad
    Quote Originally Posted by Stvwndr219 View Post
    I replaced the Koolance 5970 'original version' with a rev. 2 about two weeks ago, and the VRM temps are much improved, by about 40C. There were definitely areas where the VRMs were not being cooled properly using the original version.
    Antec P193 / 2 x Sapphire 5970 OC / Creative X-Fi Titanium / Killer 2100 / 3 x 160GB X-25M Intel SSDs / 1 TB WD Caviar Black / 1200W Thermaltake PSU / Liquid-cooling: Koolance TMS-200 / RP-1000 / EHX-1320 4 x 120mm rad / CPU-360 / VID-597 (rev. 2) / EK x58-UD7 / TMG-1 120mm rad
    Jul 2006
    norway
    finaly ALL parts have arrived, after miss ordering wrong barb sizes and adding a lot of parts to my original list.
    knowing myself this will be a fast and furios assembly with little regards to static electicity and leak testsing, wish me luck til the weekend and x-fingers
    Corsair HX 1000 psu
    cooling:
    -ek mosfet WB
    -swiftect micro res
  18. #18
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    Quote Originally Posted by Trader88 View Post
    Is your HD5970 not cold bugged? Windows locks up for me if I drop much below 45C. I had to add an 8800GTS to the loop running F@H 24/7 and keep my radiator fans off in order to keep Windows from locking up.
