Results 1 to 10 of 10
Thread: Intel Core i7 + X58 MB + 6 Modules
    Aug 2006
    Question Intel Core i7 + X58 MB + 6 Modules
    Guys i can get a heck of a deal on a core i7 and i need the answer to this question fairly quickly. I hope someone can help me. Its just that in general does filling all 6 memory slots in your x58 motherboard severely limit your overclock? If someone can help me fairly quickly it would be GREATLY appreciated.
    thanks,
    Ncage
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Have a look at this, may answer some of your questions.
    http://www.legitreviews.com/article/879/1/
    24/7 Work & Play Rig
    Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
    EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
    Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
    Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
    Aug 2006
    Quote Originally Posted by Major View Post
    Thanks for the link but unfortunately it only partially answers my question. He shows the he is able to overclock but he doesn't compare it to overclocking with only 6GB of memory only that he is able to overclock. I think he had it up to about 3.4ghz. Currently i have a core quad that i have @3.8ghz with 8GB of Memory. If i'm going to upgrade i want to hit at least that clock or more but i know i want 12GB of memory. I know a lot of people get @3.8ghz with corei7 but they usually are running 6GB of memory.
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    I'm upgrading to 12gb in a week or two myself.
    I can't see how it would affect OCing the processor except perhaps some additional heat generated by the memory controller.
    What it will affect are the timings that you may be able to run the memory at, particularly 1t or 2t and it may also require lowering memory speed and or increasing VTT.
    But that's just a guess. I've searched for posts here and by google and have not found any answers.
    Jun 2009
    Austin, TX
    Major is partly right about how it won't affect OCing the core frequency because you can always choose a mem multiplier to keep yourself from snagging into ddr speed boundaries. However, from things I've seen and experience I have with silicon validation, (Tom's Hardware did an article a while back, but I don't have the time to look for it) going from 3 slots to 6 slots can reduce your mem OC anywhere from 50 to 150mhz. Nothing huge, but certainly noticeable, but going from 3 to 6 slots will always introduce some sort of coupling as two dimms will be sharing the same memory channel. Unless you're going for the ultimate OC, I'm sure it's not going to affect your daily usage by all that much, as you should be able to hit almost any mem speed below 2000mhz without any issues.
    I do this stuff for a living... it sorta takes the fun out of it.
    Main Machine
    i7 3770k @4.7GHz 1.392v, Asus Maximus V Gene, 4x2GB Corsair DDR3 @1600 7-8-7-20 2T, EVGA GTX 580, Seasonic X-750, Silverstone FT02
    Cooling:
    XSPC Raystorm Acetal CPU Block, EK GTX 580 Black Acetal Fullcover, Swiftech MCP655 pump w/Koolance RP-452X2 Bay Reservoir, Magicool 3x180 MC-RAD180X3 Radiator
    Retired Machine
    Member of the 4.5GHz LinX Stable Club
    Windows 7 Ultimate, i7 920 @4.1GHz 1.31v Batch 3849A866, Asus Rampage 2 Gene, 3x 2GB Corsair DDR3 @1950 8-9-8-20 1N, EVGA GTX 275 896MB, Antec Truepower 750W, Antec 902
    Cooling:
    Swiftech GTZ CPU block, Swiftech MCW60 GPU block, EK ASUS-HP NB block, Swiftech MCP655 pump w/EK Top, Swiftech MCR320-QP radiator w/Scythe Ultra Kaze 2000RPM (rheobus controlled), Swiftech MCR120-QP radiator, XSPC single bay reservoir
    File Server
    Ubuntu 12.04: Underclocked i5-2500k, Asus P8Z68-V, 4x4GB Corsair DDR3 @1333, 3ware 9650 SE 4 port RAID card in RAID 5 with 4x1TB Western Digital Caviar Black.
    Mar 2005
    Runnin my 920 @ 4.0 with 12gb, no issues.....
    EVGA X99 FTW-K
    I7 6850 @ 4.4
    32gb Corsair Dominator DDR4/3000
    PowerColor 390 8gb x3
    Samsung 960 EVO 500GB
    4 480 Adata SSD (Game array)
    X-Fi Titanium
    1600 watt Lepa
    Custom water-cooled Enthoo Luxe
    (proc,motherboard,vid cards)
    Windows 10 Pro
    Jun 2009
    Austin, TX
    Quote Originally Posted by cstkl1 View Post
    well ive seen a few ppl doing 12gb 2k C8/C9
    again..
    depends on ure ability
    and ure mobo
    and ure ram.
    Well yeah, it's possible to get almost anything as long as you're willing to spend the money on it, whether from buying the best components, or having the patience to cherry pick them.
    Realistically for everyday use, it shouldn't matter and if you care about hitting that crazy DDR OC, you can always (if absolutely necessary, I do stress necessary because for everyday use, this is never necessary as the gain from having more memory outweighs the few mhz you gain) pop off 3 sticks for that cpu-z, 3dmark run, etc.
    tl;dr; Buy whatever amount of RAM you deem is necessary.
    Main Machine
    Cooling:
    Retired Machine
    Cooling:
    File Server
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    I've ran up to 4.8GHz, 229 blck w/ 6 modules completely stable. C0's had issues w/ 6 models and overclocking but there shouldn't be an issue w/ most D0's.
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Quote Originally Posted by lowfat View Post
    That's good to know
