Results 1 to 13 of 13
Thread: compression fitting too tight?
    Jun 2004
    is it possible to overtighten a compression fitting? i found with my tubing (tygon s-50-HL) that after a while (ie a half-hour or so, while i was doing up other things) i could screw the collars down further, basically to the point that they're all more or less screwed all the way in. it wasn't easy to do mind, i used rubber gloves to get a proper grip.
    been leak testing and there seem to be no problems.
    Nov 2009
    I used a wrench on my barbs
    I tightened mine by hand but 1 leaked so I got the wrench out and tightened them a little more.
    Xtreme Cruncher pwolfe's Avatar
    May 2008
    /home/pwolfe
    I hand tighten with kung-fu grip
    L-l-look at you, hacker. SoulsCollective's Avatar
    Jun 2007
    Perth, Western Australia
    Yes, it's definitely possible to over-tighten. If compression fittings are tightened too much they can start to cut into the tubing, which is obviously not good and will cause you problems further down the track. You should never have to use any kind of tools to tighten your fittings, screw them down finger-tight and then maybe "kung-fu grip" ( ) them another half-turn.
    Quote Originally Posted by iNoXiouZ View Post
    I suspect your leak was from the base of the fitting not being properly tightened down (and thus your wrenching the collar also secured the base), not from the collar - in order for a compression to leak from the barb/collar section the tubing would need to be either the wrong size, and therefore far too loose on the barb, or not pushed far enough down the barb. The collar is there simply to prevent the tubing from working off the barb, not to ensure a seal.
    Rig specs
    CPU: i7 5960X Mobo: Asus X99 Deluxe RAM: 4x4GB G.Skill DDR4-2400 CAS-15 VGA: 2x eVGA GTX680 Superclock PSU: Corsair AX1200
    Foundational Falsehoods of Creationism
    Nov 2009
    It was just a standard barb (not a compression fitting) in a XSPC Res top, the barb goes in at a slight angle and so I either needed to tighten it more or get some more rubber gromets
    Jun 2007
    I see.
    I'm a little curious as to why you're posting this in a thread about whether you can over-tighten compressions, then
    Rig specs
    Xtreme Addict rge's Avatar
    Jun 2007
    Whether you use barbs with clamps or compression fittings, over time the tubing will be compressed, and allow further tightening. I dont know if its necessary to tighten any further, and I dont, just an observation.
    I use 3/8 5/8 ie thicker tubing with compression fittings for quite a while, and all of mine are always tightened all the way down, and none of mine have cut into tubing...maybe with the thinner wall tubing its a concern, or maybe depends on the particular brand of compression fittings. I can tighten most of mine all the way down by hand, but it gets tiring, so I use rubber tipped pliers and just tighten all way down. On other side, may not be necessary, but I have never had any leaks, so will continue to do it that way.
    Nov 2009
    Quote Originally Posted by SoulsCollective View Post
    I see.
    Just pointing out that if tightening by hand isn't enough then you could use a wrench.
    Jun 2007
    Except that a straight barb is an entirely different thing than a compression fitting.
    Rig specs
    Nov 2009
    Ok I know the differences between a barb and a compression, however my point is still valid as you could use tools to tighten either a barb or a compression fitting.
    Jun 2007
    Yes, you could, in the same way that you could use a blowtorch to both light a candle and repair your car. The use of the tool will have entirely different consequences depending on the specific application - in this case, using a wrench to tighten the collar of a compression fitting has a not insignificant chance of puncturing your tubing, causing system leaks.
    Rig specs
    Nov 2009
    I'm talking about tightening the fitting to say a GPU block, not tightening the compression on the tubing, Sorry if I wasn't clear.
    Wish I never posted
    Xtreme Member Philwong's Avatar
    Jul 2006
    Singapore
    Quote Originally Posted by rge View Post
    I use 1/2" OD tubes on 1/2" BP compressions tightened all the way down, too. So far so good, no leak, cut or whatsoever.
    Phil
    i7 4GHz ♦ Asus R2G ♦ OCZ Intel XMP ♦ Asus 5870 ♦ Crucial M4 ♦ Swiftech ♦ Koolance
    X4 3.5GHz ♦ Biostar 890GXE ♦ OCZ AMD BE ♦ Asus 8800 ♦ WD Veloci ♦ Swiftech ♦ XSPC
